Wastegate vs none
Old Dec 24, 2007 | 03:14 PM
WVAussie's Avatar
Wastegate vs none
I need to replace my exhaust housing and see that HTT has non wastegated housing. They don't issue any warning in the decsription so what are the pros and cons of non wastegated housing?
Old Dec 24, 2007 | 04:24 PM
Joker12valve's Avatar
You have about the same setup as i did when i put a 14 non gater housing one my truck. with water and 215 injectors i would see 35psi at 3000rpm other wise 30psi. it was quicker to spool and droped egts a good amount, can't rember how much thought. then i made it a hybred 2 weeks later. good set up made 306 at the wheels with it fun to drive. Also the non gated is alot cheaper.
Old Dec 24, 2007 | 04:43 PM
WVAussie's Avatar
So you didn't any problems with too much boost? I am wanting to grind my plate soon and advance my timing. I thought that my wastegate was leaking but I can make 16 -18 psi with the accuator disconnected and that seems to be about right I think. But the wastegate is stuck.
Old Dec 24, 2007 | 06:05 PM
j-fox's Avatar
A non-wastegated housing can push the drive pressures very high. Then the headgasket goes!!
Be carefull spinning a turbo too high by not using a wastegate.
Old Dec 25, 2007 | 12:37 PM
my head gasket is stock with now studs, with the 100 plate mid way alot of water and timing at 14, never had a problem, and garret has diven this truck and he diden't have problem. Would see 40psi all the time, 45 on a long pull to 3k. I put the 5k, springs, 17 timing full cut dvs htt 62 14, 50psi all day long on a stock head gasket, for how long the world may never know.
Old Dec 25, 2007 | 03:57 PM
WVAussie's Avatar
So if boost is kept to under 35 lb everything should be fine, right. Do you have try hard to keep it in that range. I don't mind if its something that I just have keep on eye at times but if it someting that is going to require full time attention I can do with out that.
Old Dec 26, 2007 | 08:12 PM
never had to watch the boost, Egt was another story. never had a problem it the it.
Old Dec 28, 2007 | 08:37 PM
Beat93's Avatar
i have a 5 speed 215 pump #10 plate in the middle, afc in the middle and with my stock turbo and a rusted shut wastegate i see 46 psi easily if i beat on it at all in 3rd gear + i have stopped driving it hard until i get a new turbo. to much boost for the stocker.
Old Dec 28, 2007 | 09:24 PM
HOHN's Avatar
Basically, yes. Keep the boost down and your non wg turbo will live just fine.
jmo
95turbo4wd
Dec 8, 2007 06:09 PM
EClancy
Nov 8, 2005 03:53 PM
oestreich84
Oct 7, 2005 06:05 AM
kevteri
Jul 28, 2005 09:35 AM
thumper 549
Jul 22, 2005 08:26 PM
