none of my gauges are working
Old Dec 7, 2007 | 01:39 PM
95turbo4wd's Avatar
none of the gauges in the dash work, also the 4wd light or " wait to start" dont work either.... i checked all fuses... im stumped... any ideas????? this just happend i have a 95 5 spd
also i just noticed the odometer dont work either.. its not counting miles as i drive it... help anyone?
Old Dec 7, 2007 | 02:22 PM
dssimecek's Avatar
Don't know if this will work on a 95, but on an 02 a gauge check is done like this.
Hold the odometer reset know in, and turn the key on. The odometer window should come up and say "chec" and then do a snake dance. All the lights should come on. The gauge will go up, like 1/4 1/2 and all the way up. Like the spedo will show 120. Not sure what this would tell you except the instrument panel is working.
Let us know what you find.
Old Dec 7, 2007 | 02:42 PM
95turbo4wd's Avatar
i dont think that will work on a 95... my odometer is manual not digital..... .
i just tried it and it did nothing
Old Dec 7, 2007 | 04:18 PM
joker_800watts's Avatar
sounds like you got the same issue i have sort of. i have a broken wire some where not letting my Tach work no Alternator , getting lots of codes that sensor output to high ECT.
the way to get codes on the 95 is key on key of key on key off key on and watch the check engine light it will flash the codes. 23 will be 2 blinks followed by a short pause then 3 more blinks. but if your check engine light does not come on then you can't pull codes either.
Old Dec 8, 2007 | 06:09 PM
95turbo4wd's Avatar
well it keeps getting worse... now my brake lights are staying on all the time.. even when you turn the truck off... my high beem indicator is always on, even when there off.. nothing works in the gauge cluster... and my park light fuse keeps blowing
also now my brakes are mushy and push to the floor... ughhh
anyone?
WVAussie
Dec 28, 2007 09:24 PM
EClancy
Nov 8, 2005 03:53 PM
oestreich84
Oct 7, 2005 06:05 AM
kevteri
Jul 28, 2005 09:35 AM
thumper 549
Jul 22, 2005 08:26 PM
