Walbro question
Walbro question
i am currently running the stock lift pump and the BD auxillary pump. With my juice on level four I drop below 9 PSI . When you guys use the walbro do you eliminate the other pumps and just run the Walbro?
Yea you have to ge rid of the others. The walbro by it sell can make crazy pressure and flow. With out the regulator it blew the water in fuel sensor out of my filter housing. You can buy the kit from gdp or you can just get the pump, regulator, and strainer and hook it up to your existing plumbing inplace of the pusher pump. But thats only if you already have the big line kit on.
Walbro
Thanks guys. This Juice with Attitude really throughs the fuel and under heavy throttle the fuel pressure falls below the magic 10psi. So when the lift pump shows signs of dieing it will come out and I will go with the Walbro.
This is a great source of info.
Southern Pride
03-23-2007 08:50 AM
