vp44 longevity
Old Jan 27, 2007 | 04:33 PM
squirrel's Avatar
so why are the vp's failing? is it electrical or mechanical reasons? has anybody pulled one apart to see what caused the failure?
Old Jan 27, 2007 | 05:01 PM
cumminsdriver635's Avatar
They fail both electronically, and mechanically, but I think most the time it is the electronics that are failing.
Eric
Old Jan 27, 2007 | 05:14 PM
natlchamp2k4's Avatar
http://www.arb.ca.gov/fuels/gasoline...22003bosch.pdf
Some info I found on Fuel Lubricity. I think Ill start using lubricants again.
Any anything you want to know about the VP44, very very detailed. This place sells components, if you were good you could rebuild one your self it looks like.
http://www.chinahanji.com/injectionpump/VP44.asp
Just click on Vp44 and a drop down list of parts comes up.
Im having problems finding anything made published about failure
Old Jan 27, 2007 | 07:14 PM
John_P's Avatar
natlchamp2k4:
Thanks for the links! Good information there.
Topper:
Your post was also good on the number of VP-44's that are currently on trucks that are so low on F.P. because of a bad or dead lift pump! The number of VP-44's that fail between the two Dodge dealers here where I live is pretty high! The two Dodge Cummins Technicians that I deal with will get a 24 valve truck in for poor performance, hook their mechanical gauge up to the port on the canister or pump and look at the gauge to see 3-5lbs at idle! That is pretty common in these two dealers!
I would like to see the numbers from D/C too.
John_P
Old Jan 27, 2007 | 08:51 PM
linetrash75's Avatar
I don't think the VP-44 is as bad as its made to be on here the stocker went 197k on my truck. And $1000 for a rebuild isn't bad, figures up to $.005 per mile, tires figure to about $.014 a mile, or more.
Jed
Old Jan 28, 2007 | 12:17 AM
J BODY's Avatar
I've installed over 125 VP's since 99.
Old Jan 28, 2007 | 02:58 AM
BigBlue's Avatar
You really need to get out more often if you count the number of injection pumps you've installed.
Old Jan 28, 2007 | 10:18 AM
J BODY's Avatar
.....actually all I had to do was to run the labor ops code and the puter brought the number up for me. I then estimated how many CP ones I did using a conservative #. Either way you look at it, for a part that costs that much, I would expect a better track record. I can only hope the one I installed on mine in 2005 will last a good long time.
Old Jan 28, 2007 | 10:41 AM
LUKE-MM-PULLER's Avatar
I know a guy thats got 240k on the stock lift pump and vp44. I also beleive that the vp44 is not that bad of a pump. I had 142k on my truck when the lift pump when and took the vp44 with it. I'm hoping this one will go just as long.
Old Jan 28, 2007 | 12:24 PM
newconcorddodge's Avatar
My Vp and lift pump both went out at 103,000 miles and had no signs that anything was wrong until the truck shut off while driving down the road. I think thats not too bad considering i have driven 2,000 miles since it was replaced in November and 9,000 since i bought it last March so if i put on roughly the same # of miles the next few years the pump should last longer than the original. I am also convinced that the previous owner had a comp on it but the dealer had no idea. I plan on adding a Edge Juice w/ attitude so i'll have gauges. Theres my 2 cents
lumpy_63
Jul 13, 2009 08:37 PM
rjrkihap
Aug 26, 2005 07:57 PM
supercharger
Mar 22, 2004 09:34 AM
sdgunslinger
Apr 5, 2003 07:42 PM
jlells01
Feb 1, 2003 03:57 AM
