Turbo Blow Off Valve??
I agree with KP. Blow off valves are no where near as efficient as an external wastegate, in controlling higher boost levels. BUT, if you add twins, and have not yet done head work, it's an easy, cheap, short term way to protect your head gasket.
RJ
I ran a Tial 38mm Ext Wastegate on a KSB-1, rated to 425 hp. The Ext WG took me comfortable to almost 500 hp and worked flawlessly. Tial uses a regulator and is fully adjustable.
http://www.tialsport.com/
RJ
RJ
Sorry, guess I did not say it very clearly. I ran an Ext. WG before I got twins...when I had a single KSB-1. By passed exhaust directly into down pipe with 2" flex pipe.
![](https://www.dieseltruckresource.com/pics/data/500/medium/27851CTD-1_15_05_013.jpg)
RJ
RJ
Yup! Full boost pressure bleeds off to bottom of Tial WG and fights a 21 psi spring. Regulated boost runs to top of WG and adds pressure up to full boost in helping the spring and exhaust valve stay closed! So you can have anywhere from 21 psi boost up to full boost, unregulated from the turbo.
Worked slick!
![](https://www.dieseltruckresource.com/pics/data/500/medium/27851External_W_G_Air_Tap_T_3_9_05.jpg)
![](https://www.dieseltruckresource.com/pics/data/500/medium/27851External_WG_Air_Tap_Regulator.jpg)
RJ
Worked slick!
RJ
Blow off valves serve no effective purpose on an engine without a throttle (our diesels). The purpose of blow off valves on gassers is so when you let off the go pedal quickly and the throttle butterfly slams shut, the rapid increase in compressor discharge pressure is relieved. On a diesel, you dont have a throttle and thus you dont have this problem.
Nope. Diesels don't have any throttle blades. A blow off valve is used to blow off the pressure that is there when you slam the throttle body shut on a gasser and is actuated by vaccum. A pop off valve is there to control the pressure and is operated by springs so to speak.
Any other ideas on brands of wastegates that I could look into other than Tial and Turbonetics? I want make sure I cover all my bases here. Thanks.
D
D
The throttle adds fuel which in turn creates more need for air which the turbo takes care of. The more fuel you put to it the more boost pressure you'll get. Diesels only need fuel and air to run.
lilbitz909
05-30-2008 02:07 PM
Igor
15
04-03-2006 11:54 AM
