TST vs Comp
Old May 24, 2006 | 02:10 PM
getblown5.9's Avatar
TST vs Comp
if i swap my comp for a TST and lose the timing...will i see a power loss.
my plan is to then save for a smarty
will a smarty/TST stack be safe on stock headgasket
Old May 24, 2006 | 05:59 PM
graphitecumnz's Avatar
Both the Comp and the TST are rated for 120hp... they just get there differently.
Who knows about the headgasket... my brother sled pulled all last year with a Hot TST, Mach 6+ and SP66 on the stock gasket(no studs or orings) and it was fine.. made several 500+ dyno runs and it was fine... just popped on sunday while passing a car on the highway...
Old May 24, 2006 | 07:43 PM
Charlie8301's Avatar
Dont see where it would be any harder on it the then the comp. You might see a rise in egt's when running just the TST becouse of the lack of timing.
Randy
Old May 24, 2006 | 07:48 PM
dzlfarmboy's Avatar
Yeah with just a TST you will lose your timing but if you can get a smarty with it, it should be a pretty nice set up. But you get both with the Comp. So it's more cost effective. But the TST Smarty combo might be a little better.
As far as your headgasket goes it should be fine as long as you keep your boost under 45, maybe a little more but thats iffy. Just my 2ct
dodgediesel
14
Dec 14, 2006 09:54 AM
dodgediesel
24
Oct 25, 2006 04:40 PM
getblown5.9
13
Oct 4, 2006 04:59 PM
rockjeep73
Mar 25, 2005 03:34 AM
hellotbone
Jul 12, 2003 12:58 AM
