tst power max 3 help
Old Feb 17, 2010 | 03:38 PM
crash4wd's Avatar
i recently got powermax 3 and i cant get this thing to work i have read directions checked connections and this thing doesnt do nothing all lights on and it just doesnt feel there on the remote the green fuel light doesnt light up any ideas
Old Feb 17, 2010 | 11:26 PM
pind's Avatar
sounds a lot like a bad connection at the VP, to be totally honest.
As long as you tapped the right wire, it "should" work. however, if you used the supplied scotchlock connector, it can go bad. I've had it happen a couple times on customer's vehicles.
double check that, and your boost pressure sensor connection. I am thinking one of those two is the culprit.
Old Feb 18, 2010 | 08:42 AM
AggieJustin's Avatar
While you're looking at the lights on the front of the box (not the remote), do you see any change in intensity while you're driving? The green fuel light on the box should get brighter as boost rising and additional fueling is being delivered.
Old Feb 18, 2010 | 02:20 PM
crash4wd's Avatar
on the box the green light doesnt really get bright it gets a little brighter but not much and it flickers alittle and i used the posi tap connecters
Old Feb 20, 2010 | 04:25 PM
crash4wd's Avatar
ok well i took chip apart put it back on and now it works for about 30 sec and then its stops fueling everytime i unplug it will fuel for abou 30 sec does anyone have ideas
Old Feb 20, 2010 | 07:31 PM
DIESELWRKS's Avatar
I would contact TST about it on the site they have alot of troubleshooting tech stuff
Old Feb 25, 2010 | 02:56 PM
crash4wd's Avatar
i did they told me to tie the two egt wires together and that didnt work they are looking in to it i didnt know if anyone else had this problem
crash4wd
MDDTR #33
Feb 19, 2010 05:46 PM
dieselman24
Feb 12, 2004 08:33 PM
Mr. 45
Aug 28, 2003 12:42 PM
Zino
Aug 15, 2003 10:14 PM
hellotbone
26
Feb 7, 2003 09:31 AM
