New turbo (Advise)
Old Feb 21, 2010 | 07:12 PM
Spencer Denton's Avatar
New turbo (Advise)
I was thinking bout puting a biger turbo on my 24v but dont realy know how much thay do. If thay dont do much then ill get injectors instead. Any sugestions?
Spencer
Old Feb 21, 2010 | 09:11 PM
Big Deezul's Avatar
if your truck is stock...keep the stock turbo.
Old Feb 22, 2010 | 10:50 AM
Midnite's Avatar
Turbos don't make power--fuel makes power. Turbos help cool EGT to allow you to add more fuel.
If you haven't done anything to your truck yet, I'd recommend a box first, like the Edge EZ.
Mike
Old Feb 22, 2010 | 07:12 PM
DodgenIt's Avatar
X2, if you tuck is stock, start with gauges, intake, exhaust, fuel system.
Then thow in a chip or pogrammer. the gauges will let you keep things safe for the engine, same with fuel pump, and intake and exhaust will help the truck flow better.
Stock turbo can handle quite a bit before being over worked.
Old Feb 22, 2010 | 09:08 PM
rebal's Avatar
everything that was said^^^^^^
Old Feb 23, 2010 | 09:57 PM
oh ok got ya now then ill be geting some new injectiors. Thanks
Spencer
Old Feb 24, 2010 | 01:21 PM
Mike Holmen's Avatar
The Guru
Spencer you driving an auto truck or auto? Which injector you thinking about running?
Yes, an aftermarket turbo will make more power on a stock truck. The Holset is wastegated from the factory to run a 24psi. An aftermarket will not have been set so low. Secondly even stock injectors you can get to smoke and make egt's with the right combo. Going from a stock 24v injector to my ddp 110's sticks, my egt's and smoke decreased.
Old Feb 24, 2010 | 09:58 PM
i have a 5 speed but im now thinking about puting a diffrent chip in it
Old Feb 25, 2010 | 07:37 AM
The Guru
The edge attitude works pretty good and comes with gauges. A set of RV275 injectors would wake up the truck. The only problem is that you'll need to do some fuel system mods and a clutch upgrade
Old Feb 25, 2010 | 08:03 PM
what about the superchips Flaspaq is that a good one or what?
Old Feb 25, 2010 | 08:15 PM
The Guru
Nope, no good, waste of money.
I would look for an edge comp box or attitude. They are available reconditioned from edge, or buy one used. I put down 315rwhp, just with a stock truck and a edge comp box, 380rwhp on a stock truck using the 90rwhp injectors and edge comp box. 265rwhp with edge ez tow and 300rwhp using ez/90rwhp sticks.
The smarty stacks pretty good with the edge, the truck will respond better all around with the smarty but it doesn't add any power on the dyno. The cruise will act goofy on any of the catcher modes.
Old Feb 25, 2010 | 08:59 PM
Oh ok were do u think is a good webiste to look at them?
Old Feb 25, 2010 | 09:06 PM
Also do u think i need the one with the montior or not?
Old Feb 25, 2010 | 09:07 PM
Big Deezul's Avatar
yes get the monitor for sure
Old Feb 25, 2010 | 09:13 PM
ok dose any one know were to get a good deal on a new one is because thay aint cheap?
