TST comp help
Old Jan 16, 2007 | 10:06 PM
inline6power's Avatar
TST comp help
ok guys i just got another TST and yes its a COMP this time worked great for the first day, now i get like a stumbling effect. truck really really goes, then falls on its face, then goes, then falls. as it is doing this, the green fuel light flickers so i no its electrical. i just put in a new map sensor so thats not the case. fuel pressure is at 31 at idle and 24 at WOT so fuel is not the problem. do you guys have any ideas?
Old Jan 17, 2007 | 12:08 AM
BigBlue's Avatar
Check all the connections again and make sure they are solid. If that's not the case then it might be the box or injection pump. I'd check for codes.
Old Jan 17, 2007 | 01:20 AM
Ph4tty's Avatar
When Getblown was having a simular problem it turned out to be the fuse, even though the fuse he had looked good.
Old Jan 17, 2007 | 08:32 AM
BOILERMAKER's Avatar
I cannot stress this enough with the TST. SOLDER THE CONNECTIONS. I had some problems and was getting really frustrated with my pm3 .............................................. needless to say, soldering was my problem.
Old Jan 17, 2007 | 10:13 AM
getblown5.9's Avatar
if only the green light is flickering check the IP connection and also check for IP failure codes.
why are you stacking a drag comp with the TST comp. an EZ is much cheaper than a drag comp and will do the same thing.
lastly what remote do you have? is it the kind that has gauges and will allow the TST to defuel when the parameters are exceeded? i had that issue, i never hooked up the EGT probe, and when the EGT gauge on the remote didnt get a signal it would disable the TST fueling. you have to turn it down all the way til it says OFF and then you wont have the backdown feature anymore.
check those and get back to us
Old Jan 17, 2007 | 11:29 AM
got her fixed. it turned out to be the fuse, like you said, it looked perfectly fine but i guess it was bunt on the tip where you could not see. changed it, and bam, works like a champ.
as far as the DRAG box goes, thats what i had to start with, and i wanted to keep it and stack it with the TST comp and that way if i didnt like the TST, i would still have my DRAG comp. but now that i have actually tried the stack with the TST comp, and not the regular TST i will probably sell my DRAG comp and get an EZ and that will give me a little money in the bank.
Old Jan 17, 2007 | 12:12 PM
Glad you got it figured out!
Old Jan 17, 2007 | 02:56 PM
thanks for your guys help. i was getting very very frustrated thinkin i was a becuase i know i checked everything. thanks again.
Old Jan 17, 2007 | 04:14 PM
Beeram305's Avatar
You could give the smarty a shot as well, you might like it more than the EZ, just more expensive.
Old Jan 17, 2007 | 04:31 PM
hey my buddy has an 03 with all the goodies, i think lol. he has the HOT juice attitude with water meth and i eat him alive. what is a good programmer or box to stack with the HOT juice? does the smarty stack well with it.
dodgediesel
14
Dec 14, 2006 09:54 AM
dodgediesel
24
Oct 25, 2006 04:40 PM
getblown5.9
13
Oct 4, 2006 04:59 PM
rockjeep73
Mar 25, 2005 03:34 AM
hellotbone
Jul 12, 2003 12:58 AM
