Superchips Tuner Problem
Old Jan 21, 2007 | 08:53 PM
debolton's Avatar
I just installed the Superchips tuner last week for my 02 Dodge 2500 CTD and have noticed it appears to be surging mostly at idle and some while on cruise control. My truck is BONE STOCK!!! (with the exception of adding this tuner).
Has anyone else experienced this problem? What did you do to solve it?
By the way: When I returned it to stock mode the surging went away.
Thanks for any advise.
Old Jan 21, 2007 | 09:20 PM
merrillr4's Avatar
Have you checked for codes yet? I hope you do not have the death code showing!!
Old Jan 21, 2007 | 09:32 PM
biododge1's Avatar
i replaced the fuel filter on mine and that problem went away----get gauges if you don't have them
Old Jan 21, 2007 | 09:41 PM
debolton's Avatar
Death Code?
Death code?????
What is that code and what does it mean?
Old Jan 21, 2007 | 09:43 PM
debolton's Avatar
I have a Fuel Pump gauge installed. It saved me from having my VP44 replaced. I just had the lift pump conversion done last week.
I replaced the fuel filter about 2500 miles ago. Do you think that it could be clogged up that guickly?
Old Jan 22, 2007 | 12:54 AM
Big Smoky's Avatar
Death code?????
The death code is 0216. If you get that code that means your IP is fixin to die! I think the code actually means injections pump timing failure.
Old Jan 22, 2007 | 05:38 AM
ib516's Avatar
I had a Superchips tuner at one time too, on my otherwise stock (at that time) 2002. I felt it made the truck surge a bit (nothing dramatic) when I was coming to a stop at a stop sign or red light. It's normal when running a chip or programmer (unless it's severe). The surge you feel while in cruise control mode could be explained as follows:
Superchips makes "some" of their "extra power" by jacking up the throttle position calibration. For example, 75% throttle input may be read by the ECM as 100%. This makes the truck feel more "powerful". This is done intentionally by Superchips (and other tuners too) along with adding more fuel to increase perceived power. What does this have to do with your surging? The ECM and cruise control are programmed such that if the cruise control needs to gain 1-2 mph, it tells the ECM to give the amount of calibrated throttle input needed to achieve that. Now that Superchips has reprogrammed the ECM, that amount of throttle input is too much, as the truck surges ahead, then quickly backs off to prevent overshooting the cruise setting. My Edge EZ does the same thing, but you have to be paying attention to notice it happening. Put a trailer behind it, and it turns from a little annoyance to a benefit - it doesn't lose as much speed when it needs to adjust. The more aggressive throttle (and more fuel which = more power) works well in that situation.
Now, if the truck is idling and surging while in park (or neutral if 5 or 6 spd), that's different.
Your fuel filter could be clogged in 50 miles if you get a bad load of fuel. Your FP would have to be low before you'd notice drivability issues.
Old Jan 22, 2007 | 12:26 PM
debolton's Avatar
I too don't feel that what I am experiencing is "dramatic" just very annoying. Expecially since it doesn't do it when I reload the "Stock" mode.
So, if I understand you correctly this is something I must learn to tolerate ... correct?
Thanks for all the info.
Old Jan 22, 2007 | 04:43 PM
RAF's Avatar
RAF
I haven't had any problems with mine. I have only run the High performance mode since I got it.
Did you check for codes yet?
Old Jan 22, 2007 | 04:49 PM
RAF's Avatar
RAF
There is one other thing that I did install when I got the SC. I installed a boost fooler and elbow. I don't know if this would make a diffence or not. Just to give you the whole picture.
Old Jan 22, 2007 | 05:54 PM
Twodiesels's Avatar
I hadthe same problem I sent it back they reprogrammed it, and still did the same thing. it was under warranty so i got my money back and bought the edge.
Old Jan 22, 2007 | 06:13 PM
debolton's Avatar
I called Superchips and they are blameing it on my truck even though the problem went away when I set it back to the stock settings.
Can we say software problem, Superchips?!!!
I also going to send it back for a refund and get me a Smarty.
Anybody have a Smarty?
Old Jan 22, 2007 | 09:32 PM
kpeterson's Avatar
I had the identical problem sometimes, it would even stall the truck when shifting gears, turns out that the vp44 was bad and now it works just fine
Old Jan 22, 2007 | 09:38 PM
debolton's Avatar
So I take it you had to replace your VP44 ... ouch!!! I have heard that those things are VERY expensive.
I checked for codes and none were found. Did your VP44 throw codes before it went out?
Now I'm not sure if I should keep it or send it back.
HOdiesel80
Mar 22, 2007 12:19 PM
kyle@ftlb
15
Oct 22, 2004 07:32 PM
thecatsfan
Feb 11, 2004 01:58 PM
TurboPirate24v
Dec 31, 2003 11:12 AM
joel
Aug 14, 2003 08:03 PM
