Superchips Tuner and Edge EZ
Old Dec 31, 2003 | 10:03 AM
TurboPirate24v's Avatar
I would appreciate any comments from those who have stacked a:
Edge EZ
Did you see any performance increase compared to an EDGE EZ by itself ?
Old Dec 31, 2003 | 11:12 AM
billg's Avatar
Here is a few threads that talked about this.
https://www.dieseltruckresource.com/...ht=supperchips
https://www.dieseltruckresource.com/...ps+micro+tuner
If you do this you need to be careful. Program the truck with the tuner first then add the EZ. Someone said in a post that it messed up his EZ when he had it hooked up and ran the programmer. Just be sure the EZ is not plugged in to the truck whenever you run the Supperchips Micro Tuner.
You can also do a search on stacking EZ and find a lot of reading.
As you can see I have the Supperchips tuner in my Signature. I will be adding the EZ after the trany in January.
Hope this helps
Good Luck
HOdiesel80
Mar 22, 2007 12:19 PM
hotdram
Sep 19, 2005 08:57 PM
kyle@ftlb
15
Oct 22, 2004 07:32 PM
thecatsfan
Feb 11, 2004 01:58 PM
joel
Aug 14, 2003 08:03 PM
