stock fuel plate into a #0 plate
Old Jun 21, 2005 | 02:38 AM
Rockcrawler's Avatar
I was reading that you can grind down a stock fuel plate into a #0 fuel plate? i wanted to do this for when i do truck pulls.
Old Jun 21, 2005 | 03:11 AM
P.O.R.'s Avatar
you can grind your plate into anything you want, are you asking how to do it ? or what they look like...
Old Jun 21, 2005 | 09:28 AM
TxDiesel007's Avatar
Grind it flatt..
Remove it and grind the profile flat, it looks as it says...
Tx
Old Jun 21, 2005 | 09:29 AM
Grind it flatt..
Remove it and grind the profile flat, it looks as it says... PS do not use a dremel, use a file instead..
Tx
Old Jun 21, 2005 | 10:33 AM
Txwelder's Avatar
Why not use a dremel?
Old Jun 21, 2005 | 10:45 AM
gunracer1's Avatar
use a real grinder, a dremel would take forever and a file will not touch it. these things are hard. do a search on grinding plates. i posted it up a while back. a #0 profile is about 60k back from the front flat portion of the plate. but it really doesn't matter, since the plate can be moved back and forth to get the desired fueling level.
Old Jun 21, 2005 | 11:34 AM
I was told not to do it for warping reasons
My zero plate came from a good friend and my dad ground the homeground 100 in my box right now, but im not happy, too high egts and not enough blower.. it wasnt my dad that told me tho, so im sure he used a grinder... but gunracer is right, how can it warp? it is kinda thick now that i think about it..
Tx
Old Jun 21, 2005 | 12:13 PM
gunracer1's Avatar
you don't need to worry about warping it, but i would try to keep it from over heating. i just use a glass of water and grind till it gets to hot to hold then dunk it and grind again.
Old Jun 21, 2005 | 01:02 PM
so i just grind off the bottom piece till its flat? I can do that. Does anyone have a pic of theres? Thanks
Old Jun 21, 2005 | 04:24 PM
govspringbounce's Avatar
http://www.turbodieselregister.com/f...d.php?t=122032
Old Jun 22, 2005 | 02:04 AM
thanks im glad i saw that i would have ground it really flat instead of just that.
Old Jun 22, 2005 | 10:28 AM
Txwelder's Avatar
I used a dremel tool and it took a total of about 10 minutes. I just used a really hard stone and it seemed to go down quick. Guess if I was wrong in doing that I will find out at some point.
Old Jun 22, 2005 | 10:52 AM
gunracer1's Avatar
the dremel will work just fine, it is just slow.
Old Jun 22, 2005 | 09:35 PM
yeah i just ground mine down but didnt notice to big of a diffrence between my #5 plate. I put the plate pretty far forward. Whats the best place to put it?
Old Jun 23, 2005 | 11:40 AM
for most power
about 90 percent forward..
Tx
ctd4stan
May 18, 2009 02:56 PM
TNLoneWolf
17
Feb 21, 2008 06:22 AM
PEAKSTRYDE
Feb 27, 2007 11:27 AM
53 willys
Dec 17, 2006 10:39 AM
plow
Jul 20, 2005 08:40 PM
