Something other than Water/Meth in the same setup
Old Jan 16, 2006 | 01:54 PM
MasseyMan1089's Avatar
I was thinking about this is other day. Right now I run the washer fluid in my water / methanol setup. I was thinking, could you run something like the injector cleaners of the cetane boost or something like that? Anyone else experimented with injecting other stuff besides the water/meth? Just an idea...
Old Jan 16, 2006 | 02:17 PM
gunracer1's Avatar
i think about everything has been tried, even diesel. but the results i have heard were not worth the trouble. except on trucks that can't get enough fuel like common rails. but thiis is mostly here say type info i am posting.
Old Jan 16, 2006 | 02:57 PM
600 Megawatts's Avatar
Muted User
Nitromethane ??
Old Jan 16, 2006 | 03:01 PM
BigBlue's Avatar
Originally Posted by 600 Megawatts
Nitromethane ??
Now that would be interesting. I enjoy it when my diesel hits 10,000rpm and shoots 15lb chunks of piston and connecting rod 50' in the air while simultaneously splitting the block in half from front to back and grenading the head into a bunch of chunks of molten iron and watching the impeller in my turbo came screaming out of it's housing at 400,000rpm and cut my hood into two equal pieces before flying off into the unknown.
Old Jan 16, 2006 | 03:45 PM
SuperDave4x4's Avatar
That would make a great video!
Old Jan 16, 2006 | 03:49 PM
HOHN's Avatar
Pics, please.
Old Jan 16, 2006 | 04:36 PM
Some pullers mix water soluble machining oil into their water injection setups.
Nitromethane is spooky stuff. Did you know that if you put a drip of it on the floor and smack it with a hammer, it will explode?
Old Jan 16, 2006 | 04:42 PM
newriverSpecon's Avatar
I'll have to give that a try. We have ran some high concentrations in small cubic alchohol engines. Up to 80% in 1.2 and down CID. Below 70 degrees it doesn't start or run real well till it gets warmed up. Actually we had to prime them and hand feed them until they stabilized to make it work.
Randy
Old Jan 16, 2006 | 04:57 PM
BigBlue's Avatar
Originally Posted by HOHN
Pics, please.
No problem. I'll be right back.
Old Feb 17, 2006 | 09:53 PM
I bought a few bottles of "heet" tonight. I read another post and it said it is 99% methyl alchohol. So I can dillute that down to my likings. Anyone know of any other things like "heet" that are mostly methyl alcohol, short of washer fluid?
Old Feb 18, 2006 | 11:21 AM
GO 4LO's Avatar
How about hydrogen peroxide?
Chris
Old Feb 18, 2006 | 06:33 PM
Really? Ive never thought about it. Have you tried it?
Old Feb 19, 2006 | 09:57 AM
infidel's Avatar
Hydrogen peroxide is very corrosive to metals especially aluminum.
I'd be a bit leery about adding it.
Now if you injected from a cylinder of hydrogen gas you might get some good results.
Old Feb 19, 2006 | 12:26 PM
tweeter's Avatar
If you inject hydrogen peroxide, does your exhaust go blonde?
I need less coffee......................
Old Feb 19, 2006 | 02:30 PM
taken5875's Avatar
how about r/c airplane fuel some are nitro and some are meth has any ony tried this
J Lent
60
Nov 3, 2009 09:14 PM
jdpiii
Jun 19, 2008 07:34 AM
Dean Snow
Oct 31, 2007 01:23 AM
jmccart
Jan 18, 2007 03:26 PM
mooseman
29
Oct 15, 2005 11:47 AM
