Drag comp vs. Adrenaline vs. Redline box...same dyno, same truck, same day!
I just bought a Drag comp version 10.8 & I am heading to the dyno this saturday to see which box is putting it down. I plan on running the Drag on 5x4 first run. Second run, Adrenaline Dyno tune [or whichever Quad tells me to run], 3rd run, Redline 93% with Drag comp on timing. Any early bets which box will prevail?
Neither, you'll blow up your engine before your 3 results are taken! haha just jokin'
I'm thinking the Redline...unless the Adrenaline is running well that day than I dunno. Good write up/testing you will be doing though!
no Jinx on the manifold.
. I really hope its not something that I will have to buy later because of you. I know you will do a good posting on this. are you the operator or is someone else pulling the trigger. what gear is the best for a 5 speed.
good luck J.
. I really hope its not something that I will have to buy later because of you. I know you will do a good posting on this. are you the operator or is someone else pulling the trigger. what gear is the best for a 5 speed.good luck J.
I have seen dyno sheets using the Comp/Smarty stack, it loses about 30hp. The Adrenaline came alive with Smarty loaded on my truck above 3200, but lost 25hp before 3200rpm.
