Drag comp vs. Adrenaline vs. Redline box...same dyno, same truck, same day!
Old Oct 29, 2009 | 11:37 AM
Crazydave's Avatar
Dyno results
I was on the dyno on Oct 3rd, thought i would throw this in the mix.
This is with the setup in my sig.
blue - Adr2_torq (base tune)
green- Adr_comp
red- Adr2_3000 with the pump stretch at 1850
On that dyno as you can see the different settings make no real difference.
For the box swapping, a friend of mine switched from a comp to the quad. The setup was the exact same except he went to 4:10 gears. He dynoed with in like 2-3 hp from what it he was.
Old Oct 29, 2009 | 01:49 PM
Mike D's Avatar
Originally Posted by J Lent
Onernight it now & I'll have it back to you Tuesday.
That's just not possible, I'll have to do a 12 step program first.
Old Oct 29, 2009 | 06:09 PM
Mike Holmen's Avatar
The Guru
Has anybody just run a drag box vs a adr box?
J_lent, I think its time to put another turbo under the S364? Looks like got some decent numbers. I want to put back in my mach 6'rs sticks, but I break to much stuff and I daily drive this truck these days
Old Oct 29, 2009 | 06:52 PM
J Lent's Avatar
green- Adr_comp
Wow! Talk about close graph tuning?
Old Oct 29, 2009 | 06:53 PM
J Lent's Avatar
LMAO You are a dieselaholic
Old Oct 29, 2009 | 06:55 PM
J Lent's Avatar
I'd actually like to go twins, but budget just don't allow. This 64/71/14 keeps things cool as is. I might swap to a Silver Bullet & Mach 7's for next year.
Old Oct 29, 2009 | 07:58 PM
Crazydave's Avatar
Yea not much change for 3 different tunes. I was happy to see it was making power that high up the rpm band, it was brought up to about 3500 and was just under 500hp.
Old Oct 29, 2009 | 08:09 PM
J Lent's Avatar
Those tunes are the tunes which are on the quad website now?
Old Oct 29, 2009 | 10:44 PM
Crazydave's Avatar
Yes.
Old Oct 29, 2009 | 10:50 PM
J Lent's Avatar
Yes.
Cool. I'll just pick one
Old Oct 30, 2009 | 12:00 AM
Crazydave's Avatar
What you put in as a base tune (the one in the box) I think has a lot to do with how the two saved tunes behave. For example when i got the 70% tune from you my, fuel sender read correctly on all tunes. ( had the old sender from the beta testing days and the newer software didn't support it) and the wire tap issue happened on all tunes when that was in as the base.
One more thing to note, is the torq tune will only give you 2400us of pump stretch if its the base tune. If you manually tune, the pump stretch stops at 2200. If you load it, and save it to T1 or T2 it will automatically drop down to 2200, but if its loaded as a default you will have 2400 for pump stretch.
Old Oct 30, 2009 | 08:36 AM
J Lent's Avatar
Awesome!
Old Oct 30, 2009 | 09:35 PM
The Guru
J Lent, twins are about as much money as the new silver bullet. I bet you could put a S475 under you current turbo for less than $1500, and you'll have alot more air and driveablity. Just food for thought. Of course you sled pull, so that single turbo rule you might have issues. As for the bigger sticks, I found that you needed at least a HRVP to the real big sticks to work fully.
Old Oct 30, 2009 | 10:37 PM
J Lent's Avatar
The pulls I enter don't even have techs. The ones that do have techs, have a guy walking around with a clipboard asking "do you have a stock truck or are you entering the open class?" No worries about that. I might be selling some of my boxes to save up for twins soon.
Old Oct 31, 2009 | 04:15 PM
J Lent's Avatar
I just got back from dyno day.
The Drag/Redline made 544hp/1054lbft
The Drag comp on 5x5 made 600hp/1123lbft
The Adrenaline [dyno tune] made 607hp/1141lbft ...[+7hp/+18lbft over comp]
