Smarty w/ edge comp box help
Old May 2, 2007 | 07:13 PM
bigmack2500's Avatar
I just got my smarty today and hook it up. followed the instructions and went out for a test drive. I downloaded #8 catcher without timing because I am running the comp box. The throttle became very sensitive but would fall on its *** over 2000 rpm. What program would be best to download with the comp?
Old May 2, 2007 | 07:18 PM
CTD_Neil's Avatar
I've run all the even SW's with my comp and all will pull hard above 2000 rpm. With the comp alone you shouldn't de-fuel until around 2700. And the Smarty itelf will fuel beyond that to around 3000, Have you tried the Smarty or comp by themselves?
Old May 2, 2007 | 07:31 PM
I've had the comp for awhile now. My truck was faster with just the comp! I'm thinking I need to try something else, maybe i need to download timing to, but i figure the comp would take care of that part. Or maybe I need to unplug something from the comp box any suggestion and or how are u runing your set up
Old May 2, 2007 | 07:58 PM
pmtg's Avatar
maybe its that 35cm exhaust housing
Old May 2, 2007 | 08:15 PM
yea I just wint out for another test run but with smarty on #7 with timing and my comp turned off. the smarty works great but when i turn my comp back on it feels like i have major turbo lag when i get in higher gears.
Old May 5, 2007 | 12:16 PM
jeffropump's Avatar
The first thing I would want to know is how much fuel pressure do you have ?
Old May 5, 2007 | 01:25 PM
B.A.Ram's Avatar
with that much fuel on a stock turbo you are prob. choking it out up top...
Old May 6, 2007 | 07:24 PM
Awall's Avatar
With my SMarty on #2 i still have hard pull at higher speeds. For some reason it seems that guys make higher horses with the Smarty at lowest even number and COMP all the way up.. I have heard on numerous occasions that SMarty and COmp high kills top end HP
Old May 8, 2007 | 12:18 PM
I downloaded #5 catcher with timing and it does pretty good on that setting with the comp but I went ahead and ordered a HTT killer B2!! An upgrade that is going to happen sooner or later no matter what. I need to install a fuel pressure gauge though, I wish I had gotten that instead of the trans temp. Hopfully the bigger turbo solves the problem, next is coming a set of injectors, hot rod vp, new torque converter and rebuild my valve body
Old May 8, 2007 | 12:55 PM
Mike D's Avatar
That HUGE for an exhaust housing!
Old May 8, 2007 | 05:49 PM
that was the turbo that they had ordered for me, it was also before I knew about DTR!!! Hey I learned from my mistakes, I talk to DTR before I make any perchases know.
bwarning01
15
Aug 24, 2007 09:19 PM
mx684
13
Jul 24, 2007 07:52 PM
JD farmboy
May 21, 2006 01:04 PM
rockjeep73
Mar 25, 2005 03:34 AM
hellotbone
Jul 12, 2003 12:58 AM
