Smarty/TST vs. Smarty/Comp comparisons?
Anybody out there have any real world comparisons with stacking Smarty with Tst vs. Comp? I'm getting ready to buy a Smarty and I already have a Comp (drag). Which stack is better for getting more power from an H.O. see sig for setup. Thanks
The TST has performed better in every case where it's been tried, as far as I know. But this is only in a driveability sense.
On the dyno, I doubt you'd see much difference in peak power-- but I would expect the TST to show a better, fatter curve than the Comp when both are matched to the Smarty.
It's all in the dynamic timing of the Smarty.
I think with the TST you're gonna have more room to play since it is a "fuel only" box. So with the smarty you wouldn't have to worry about the settings with timing.
Where as in the COMP, you can only use the settings that don't add timing so that kinda limits you to a smaller amount of options.
~Nick
~Nick
I believe it depends upon the mods done.
I have a customer that gained 70+ Hp with the TST over the drag Comp . That was with a CaTCHERized ECM with timing. ( # 9 )
Twins, cam... to usuall stuff
Marco
Marco
several NW Bombers have tried both combos on ETHand ETC motors, the hands down winner is TST.
I would have to dig for the numbers but on an eth with tst/catcher/mach4
I believe the number was 534 or close.
maybe Don remembers
maybe Don remembers
I had the same question a couple months ago
https://www.dieseltruckresource.com/...ad.php?t=82475
TST hands down
TST hands down
ddestruel
Feb 7, 2008 08:11 AM
dodgediesel
Jul 27, 2007 08:59 AM
getblown5.9
13
Oct 4, 2006 04:59 PM
rockjeep73
Mar 25, 2005 03:34 AM
hellotbone
Jul 12, 2003 12:58 AM
