smarty-tst stack
Old Nov 6, 2006 | 05:17 PM
smoky beast's Avatar
smarty-tst stack
what are the minimum mods required to run a smarty-tst twins stack on an 2002 5 speed, I think that would be a standard output, for towing and occasional drag racing?
many thanks
Old Nov 6, 2006 | 05:20 PM
Charlie8301's Avatar
Clutch, Transfer Pump, Turbo, Guages
Randy
Old Nov 6, 2006 | 11:06 PM
Ph4tty's Avatar
Randy
Wouldn't the turbo be optional cuz he can always turn the tst down/off?
Old Nov 7, 2006 | 09:10 AM
97crewcab's Avatar
The turbo probably isn't mandatory, but why do the stack if you can't use it? Fuel is great but without a good turbo you can watch it all exit the tailpipe.
Old Nov 7, 2006 | 12:39 PM
Yeah, I was just thinking of towing
Randy
Old Nov 7, 2006 | 03:12 PM
Dieselcamper's Avatar
Save some money and do the Van Aaken V5 / TST stack
Old Nov 7, 2006 | 04:07 PM
RowJ's Avatar
None... other than gauges! But you would have to turn the TST down till you could do the others mentioned. Something to look forward to
With TST on full, your clutch will complain and your Pyrometer will peg!
I would add a big line kit now.... won't need the upgrade on the fuel pump till over 475 hp (if you have to big line kit).
Later will need turbo & clutch.
RJ
Old Nov 7, 2006 | 04:20 PM
RowJ's Avatar
Originally Posted by 97crewcab
The turbo probably isn't mandatory, but why do the stack if you can't use it? Fuel is great but without a good turbo....
Because Turbo WITHOUT the fuel is no fun! .... and most have to build hp a few dollars at a time.
I started with TST, and than a EZ/TST stack (before Smarty was on the market)..... and that was with an HY-35 turbo. Many don't realize the TST was originally designed for stock injectors and stock turbo. Thank God we are way past those days when we lived with lots of smoke and 400 hp was the cutting edge.... and a very big deal!
RJ
Topper
Mar 3, 2008 10:17 AM
LooseBoltsRob
17
Jun 10, 2007 08:52 PM
smoky beast
28
Oct 13, 2006 01:15 PM
cummnz4x4pwr
Jul 30, 2006 01:37 PM
mjpalmer
May 19, 2005 11:34 AM
