tst-smarty-mp8 vs tst-ppe-mp8
Old Aug 19, 2006 | 06:08 PM
smoky beast's Avatar
I have heard good things about the tst-smarty-mp8 stack, but it seems like it would sure be hard beat the ppe 315 hp programmer in there, any suggestions appreciated
Old Aug 19, 2006 | 06:18 PM
Austin'sDodge's Avatar
TST + EZ One of the best stacks around. The EZ is a low pressure box hence longer relief valve and injector life.
Old Aug 19, 2006 | 06:27 PM
CSAGrey1's Avatar
I don't have a TST (YET) but I do have the Smarty. I have been told that a Smarty TST PM3 stack is hard to beat.
Old Aug 19, 2006 | 06:31 PM
I was referring to the third gen stack. The TST; smarty stack is great for us 2nd gen guys.
Old Aug 19, 2006 | 10:13 PM
stang's Avatar
CSA why dont you just run the dr performance with the TST stack?
Old Aug 19, 2006 | 11:50 PM
WUnderwood's Avatar
I'm planning on running the TST and Smarty stack, and then for dyno's or drag racing the TST, MP 8, and the Smarty, but I need head studs, a tranny, and a FASS before all that happens
Old Aug 20, 2006 | 01:41 PM
BigDan's Avatar
Same goes for 3rd Gen's
Old Aug 20, 2006 | 02:58 PM
Wunderwood, How do you plan on your CP3 keeping up?
Old Aug 20, 2006 | 03:08 PM
Luken's Avatar
My stock cp3 is doing decent with the tst/bully dog/mp-8 stack. A stage 2 would work better for sure but I think he will get by for a while.
Old Aug 20, 2006 | 03:11 PM
What settings do you have your boxes on? Do you gain any power by turning your TST all the way up in conjunction with the downloader and box?
Old Aug 20, 2006 | 03:14 PM
Luken's Avatar
On the dyno it was
tst 7x5
crazy larry
mp-8 0%
at the track I usually run
tst 7x2
crazy larry
mp-8 30-40%
Old Aug 20, 2006 | 04:26 PM
RamWheelsBy4's Avatar
Luken,
Which TST program are you running, standard, early twins or late twins? Do you have timing option on the TST??
Old Aug 20, 2006 | 04:35 PM
Luken, I'm also curious if you ever dyno'ed with the TST on 5/? and how much power it lost.
Old Aug 20, 2006 | 04:38 PM
Luken's Avatar
Standard tst and I don't have the timing option.
I don't know if we dyno'ed with the tst on 5x_ or not. I remember on 7x2 + Crazy Larry it was 640.
I only gained 20hp from 7x2 to 7x5. Anything over that and it started going downhill.
Old Aug 20, 2006 | 04:39 PM
Not Bad; not bad at all.
