tst-smarty-mp8 vs tst-ppe-mp8
I just can't get over the $5,000 price tag
Minus the tranny I have spent less than 5,000 dollars on my truck... If I had that much to blow I think it would be a modded cp3, injectors, cam/springs, and a bottle...you would still have money left over.
Im running the tst and the ppe hot, I dont know a whole lot about the smarty, but everything i read is good about it. All I can say is that if there is a stack thats better then the tst and ppe hot, its definatly a damm good one. When i had it dynoed at ats, I had ats twins, fireringed heads, studs, 4" exhaust, port and polished heads, ats stage 5 tranny and the ppe hot and tst. Then it dynoed 595 and 1180tq. Since then ive added flux 2 injectors, industrial injection cp3, fass 150, snow water/meth stage 3, H2 cam, Bigger valves in the head, bd intercooler and dual exhaust. Should be done next week and am looking for some decent numbers!!!! Will keep u posted.
Ported & Polished Head
Did ATS do the head work for you? Pls PM me with who did it and how much.
Don't you run a 12 valve??
OT,
By seat of the pants....interstate blast tuning...LOL, I think I will running settings TST 03TT 4-1 with 6 degrees Auto over SW#5 on the number 2 software (the first release) and the regular MP-8 on 50%. It will hold till 105 mph from 75 mph before my rail drains...and temps rocket. Jstiegler and I are going to go dyno next or the weekend after in Meridian.
I will run my best settings with the MP-8 and TST only first as a baseline...then Smarty in the mix. Heck...maybe because of the lighter load on the Dyno I may be able to run 5-1 on the TST...even though it is not realistic on the street. I will make a bold prediction of ~625 or so based on previous experiences...or my foot will be stuck in my mouth.
On a side note...I think I got a replacement freak of a relief valve last summer...it will hold it seems pressure above 27500 no problem!
Anyhow, I feel pretty stupid now about the MP8. When I took off the MP8 I noticed that the adjustment **** terminals were broken off. So thinking that perhaps the MP8 was stuck on a high setting I called TS up and they sent me a new control harness. Installed it this morning and now I can do full throttle runs with the MP8 at 0% without a rail pressure worry. 30% setting is about all I can do hammer down still before the rail pressure hits the sensor high limit. This was with the Smarty on 60 HP no timing and TST off.
I remember you posting that you could only do about 30% MP8 on a stock CP3 and stock injectors before the rail pressure was maxed on the sensor???
paroxysym
Sep 3, 2008 10:38 AM
Topper
Mar 3, 2008 10:17 AM
metal_miner
Oct 28, 2006 02:59 PM
smoky beast
Sep 2, 2006 04:08 PM
