TST vs. TST / Edge EZ Stack
Old Mar 28, 2005 | 12:13 PM
mjpalmer's Avatar
I currently have an Edge EZ installed on my 2005 and I have purchased a TST PowermaxCR. I have read post stating that there are benefits to stacking pressure and timing boxes together. Will stacking make EGTs worse than a single box? On mid level on the EZ at WOT, I can see EGTs exceed 1350. Looking for suggestions from others that stack boxes together. I want to create more usable power without getting excessively hot.
My signature says that the boxes are stacked but I have not stacked them... yet...
Thanks
Old Mar 28, 2005 | 12:18 PM
Stoked's Avatar
I don't see an upgraded turbo in your sig. I would suggest that before you stack both boxes and crank up the numbers you look into a better turbo. The stocker doesn't really like just the TST box, nevermind the combination.
Old Mar 28, 2005 | 01:41 PM
PourinDiesel's Avatar
You can stack both with no Turbo issue.
I speak from experience and have done this.
Just make sure to setup the wastegate line provided with the powermax and you'll have no worries, provided that you do not use level's 7 or higher with and aggressive foot.
If you let the wastegate do its thing the turbo with live a long and happy life.
PS if you stack your EGT's should come down a hair with the EZ/TST combo.
Old Mar 28, 2005 | 04:10 PM
mjpalmer's Avatar
With a stock turbo, will the stacked box combination produce more HP with lower EGTs than the TST box by itself? I know without a new turbo, I will be limited with either setup. I appreciate the comments.
MP
Old Mar 28, 2005 | 06:06 PM
Yes, we made another 20hp on TST's dyno with the EZ stacked with the TST CR box.
Old Mar 29, 2005 | 12:13 AM
mattymac's Avatar
Plus the stack has a stonger better bottom end.
Old Apr 27, 2005 | 01:32 PM
krock's Avatar
So how is everything holding together with this stack . Any one having issues with the stock turbo yet ?. Curious cause I am looking for a good stack.
Old Apr 27, 2005 | 02:24 PM
Jeff K's Avatar
I would suggest the VA C3.1 over the EZ. Stronger bottom end and less damage to the injectors from high pressure in Don M's findings.
Old Apr 27, 2005 | 03:17 PM
Don M's Avatar
DTR Advertiser
The Edge EZ is just fine if the pressure levels are kept turned down. Its the high settings that are causing the damage. Level 2 and down are good.
Level 4 and the secret levels should be avoided for extended periods. I did have one truck with a Level 4 setting tha tmnade it 11,000 miles with little damage. It was just begining. He drives very easy most of the time though.
Don~
Old May 18, 2005 | 06:35 PM
krock's Avatar
I just picked up my warrantied EZ from my 04. I got my dealer switched it out for one for my 600. I see the EZ ties in to the map sensor , but so does my TST. So I am wondering how one stacks these two. Do you leave one unhooked and plugged in to it's self or plug them all in together?.
Old May 18, 2005 | 06:55 PM
TorqItUp's Avatar
If I'm not mistaken, I believe you plug the TST in first since it doesn't boost fool. Then you would plug the EZ into the TST plug and then the stock plug into the EZ's other plug. Sorry if this sounds confusing . It should go like this Tst<--TST piggyback plug<-- EZ<--EZ piggyback plug<--stock
Someone correct me if I'm wrong.
Old May 18, 2005 | 07:11 PM
krock's Avatar
Not confusing at all . It's the way I was thinking about hooking it up. I just want to make sure so I don't screw any thing up.
Old May 19, 2005 | 11:34 AM
cquestad's Avatar
TST 1st...then pressure box.
Topper
Mar 3, 2008 10:17 AM
pcburnout
Sep 19, 2005 07:00 PM
WhiteSport600
Dec 28, 2004 05:30 PM
K2Cummins
Sep 29, 2004 07:38 AM
lightening ram
Sep 21, 2004 12:26 AM
