Smarty settings?
Old May 10, 2010 | 09:50 AM
djjordan's Avatar
Smarty settings?
i Just put a smarty on my truck wat should i put the torque setting and the Injector duration settings on i have the big fass pump a hot rod pump 100 horse Injectors and a velair clutch
Old May 10, 2010 | 05:58 PM
DIESELWRKS's Avatar
to each their own. try some diff settings. I run SW -9 TQ-6, TIMING-2 OR 3 DURATION 2-3 AND TSTPM 7-9 ALL DAY. FUEL ECON. I use. SW-1 TQ-6 TIMING-4 DURATION 1. every truck with its set up will act diff and perf diff pending driver. so change it up and see what you like the best pending your driving. that is the nice thing of it being so tunable.
Old May 11, 2010 | 08:44 AM
djjordan's Avatar
how do you like the tst pm3 i been thinkin bout gettin one
Old May 11, 2010 | 10:43 AM
DIESELWRKS's Avatar
3 years trouble free like the fact I can drive around and not have to look at it. can set it and forget about it. with the smarty and bigger sticks this is a great combo. TST is only fueling so I can tune the timing the way I would like with the smarty.
Old May 11, 2010 | 10:48 AM
djjordan's Avatar
ok thanks man
Old May 11, 2010 | 11:23 AM
RowJ's Avatar
Originally Posted by djjordan
i Just put a smarty on my truck wat should i put the torque setting and the Injector duration settings ........
With manual tranny....TQ settings are basically immaterial! But milder may help with cruise.
For Injector duration I follow directions... set based on size of your injectors.
Key for me is settings that allow Criuse Control to function smoothly while Smarty is set on at least #7. Can be tricky.
Experiment!.... it's half the fun.
RJ
Old May 11, 2010 | 05:23 PM
DIESELWRKS's Avatar
RJ
well I dont know the TQ setting from 1 to 6 there is a big differance in how fast my truck launches. also a diff on the ammount of smoke. so unless I'm the only manulal that feels a diff its not immaterial. but with manual no matter what setting no change with cruise. has always worked.
Old May 12, 2010 | 08:19 AM
RowJ's Avatar
Interesting! I assumed the TQ setting was for the TQ Mgmt Program on automatics. Sounds like it's more of a fueling setting?
On my CTD, and several friends 6 speeds, the higher # settings, and the longer fuel duration settings, DO make the cruise control never settle down. Searches full time with boost fluctuating at cruise of about +/- 10 psi.
RJ
Old May 12, 2010 | 08:32 AM
djjordan's Avatar
wel i got 100 Horse Injectors wat should i set the duRation on
Old May 12, 2010 | 08:35 AM
J Lent's Avatar
I run duration on default. It gets choppy when I add duration.
nvr-enuf
Apr 23, 2011 12:43 AM
D.Wiggs
31
Aug 30, 2007 02:48 PM
BigDan
43
Sep 17, 2006 02:50 PM
dodgediesel
Jun 27, 2006 01:42 AM
