I have Smarty+TST which settings will net most HP
Old Sep 10, 2006 | 12:51 AM
BigDan's Avatar
Hey guys I have a friend of mine thats getting ready to race/dyno.
Is truck specs are
2003 SO 4x4
ATS 48re
PDR twins HX40/Ht3B
TST
EZ
Smarty
FASS
I'm letting him try my smarty and we need to know what combo's and levels work the best for either max HP or quickest ET.
I read a few posts but they mainly seem to be for 04.5+
It seems that people have better results with the Smarty on a higher setting and the TST on a lower one. I need specifics since a few numbers off can reslt in +- 100HP.
Can you guys help us out so we dont have to spend all day tuneing and risking getting a ticket.
Thanks
Old Sep 10, 2006 | 12:55 AM
Sloverado's Avatar
I don't have twills or an 03 but on my 05 I like Smarty on 8 and TST on 3/1
Old Sep 10, 2006 | 01:20 AM
RamWheelsBy4's Avatar
My 04.5 TST w/twins program 2/0, EZ Level 3 and Smarty SW 8 produced my best 1/4 times ever. First time in the 12s. I am having the TST upgraded for timing option and multiple programs. A lot of combos to try.
But like you said most I have seen for racing or full power are running Smarty 8 or 9, TST on the low side and pressure box 50% or less.
Old Sep 10, 2006 | 08:55 AM
abc4yew's Avatar
Check out posts by AK RAM on here and on cumminsforum.com as he has the SO with twins and uses or has Smarty and TST.
http://www.cumminsforum.com/forum/sh...ghlight=Smarty
ks
Old Sep 10, 2006 | 01:59 PM
BigDan's Avatar
ks
Well I looked through 14 pages on that post and I didnt see any really good settings. More dissapointment then anything. It didnt look like his truck liked the TST-Smarty stack. The best I saw was 13.3 with smarty on 90HP and TST on 3/3??? He had a 12.6et in his sig though
Hey Luken what settings were resulted in your best numbers?
Old Sep 10, 2006 | 03:09 PM
Dodgezilla's Avatar
AK Ram is also working out the bugs on a new set of twins and that's why you aren't seeing the great numbers you would expect.
Of course, every truck is different but I can't recall seeing any posts where the user didn't turn the Smarty up and the TST down for the best performance.....
Old Sep 11, 2006 | 11:36 AM
cquestad's Avatar
My truck ran best with Smarty on 60 no timing and TST twins 5-2 or 6-2 (try 4-6)....but...that was before I had Timing adjust on the TST.
So it is all back to the beginning again. I also had my mp-8 on 40-50%.
Old Sep 11, 2006 | 12:19 PM
Luken's Avatar
Tst 7x5 + Crazy Larry = 659
Tst 7x2 + Crazy Larry = 641
Old Sep 12, 2006 | 08:25 PM
blackmoke's Avatar
Man it is hard to pass up Crazy Larry and TST with numbers like Luken has for a Smarty and TST, but I guess Smarty and TST could make the same or more with some more time. Also I heard BD CL has caused some ECM problems? One way or another out with Edge HOT, In with TST and Smarty or BD CL. Any suggestions appreciated, I have some time yet before I change.
Old Sep 12, 2006 | 08:39 PM
lmills's Avatar
Hey Mike,
Smarty will be here Friday.
Old Sep 12, 2006 | 09:02 PM
Ramirezh's Avatar
I currently have a TST/EZ stack...I am seriously considering removing the EZ and replacing it with a Smarty...but now I don't know if I should do the Smarty or the Bullydog, or just leave it alone altogether! The big downside to the BDDL is no CL for the 03's (that I know of)
Any feedback is greatly appreciated
Old Sep 12, 2006 | 09:56 PM
Luken's Avatar
If I had an 03-04.5 I would for sure go with the smarty. I need to put my friends Smarty on and see what happens. Has anyone dyno'ed with just the tst/smarty?
Im having awesome luck with the Bully Dog....
Old Sep 12, 2006 | 10:10 PM
Bob Wagner's Avatar
big shfiter did 655hp 1115tq with smarty and tst on 3 with stock cp3 and sourceautomotive twins. and 90 hp sticks from timberline dodge
Rip knows how to clear the air
Old Sep 13, 2006 | 02:28 AM
AK RAM's Avatar
I remember the days when people thought we were crazy for stacking a downloader with the TST.
There are better ways to determine which one is the "better" of the two for you. What happened to computing the HP per dollar between the two, comparing features, and comparing options? After all, if your talking power only, what would your starting point be if you loaded the highest HP level that each one offers? Exactly the same…..check the ratings.
I would argue that if you have the time to tune, you can make the same max power with either one stacked with the TST. However, there are options and features that will make one better for the strip, one better for the dyno, or one better for daily driving. I don’t think either one is perfect for all of those, though I do have my favorite.
Old Sep 13, 2006 | 02:37 AM
pirate4x4.com's Avatar
So can you clarify here? The Smarty was on Catcher 3? And the TST was on what, 3/3, or 3/1?
Come awn guys, I have the exact same setup as Big Dan's buddy -
'03 SO with PDR twins, TST, EZ, Smarty, Fass, etc... I want to go screw around at Sac raceway, but don't want to waste time trying to reinvent a wheel someone has already done! Help a brotha out!
