I have Smarty+TST which settings will net most HP
Old Sep 13, 2006 | 05:20 AM
Ramirezh's Avatar
Originally Posted by AK RAM
There are better ways to determine which one is the "better" of the two for you. What happened to computing the HP per dollar between the two, comparing features, and comparing options? After all, if your talking power only, what would your starting point be if you loaded the highest HP level that each one offers? Exactly the same…..check the ratings.
based on that then, I would be leaning towards the BDDL as far as 'bang for buck' power-wise. The highest setting on the Smarty (170) isn't applicable for the 03's (based on their site). I can still find a PowerPup in lieu of a TripleDog....
*sigh....looks like the Smarty isn't the Smart choice for me
thanks for the feedback
I would argue that if you have the time to tune, you can make the same max power with either one stacked with the TST. However, there are options and features that will make one better for the strip, one better for the dyno, or one better for daily driving. I don’t think either one is perfect for all of those, though I do have my favorite.
Power hungry daily driven dragster
Old Sep 13, 2006 | 09:53 AM
pirate4x4.com's Avatar
Taken from their site -
SW's # 8 & #9 for the 03-04 trucks are similar to #6 and #7 but have more fuel down low and even less TQM.
Old Sep 13, 2006 | 09:55 AM
Bob Wagner's Avatar
One thing to notice. The power gains with the 03's-04's would be actually higher if we started
from a 235 Hp engine. In poor words, an 03 California truck would end up with the same rear
wheel Hp the 03 6Sp produced. I've used the same settings for the California AT truck that I
used in the 03 6Sp. For the 03 235Hp/460TQ engine the power gain is above 200 Hp.
Old Sep 13, 2006 | 11:34 AM
Lightman46's Avatar
On my truck I got 176 hp gain on #7 only and it is a 04 but you have to have the air to go with it. The best I got was with the smarty on #7 and TST on 3hp-1tq, 611 hp
Old Sep 13, 2006 | 11:43 AM
AK RAM's Avatar
Ditto, and a good point. The same thing is true with every programmer though, so nothing special there. For instance, the Extreme BDDL tune consistently lays down 160rwhp gains on SO (250hp) trucks. We underpowered guys definitely get more bang for our buck.
Where the Smarty really shines on the SO engines is Marco did a much better job with torque management programming than Bully Dog has so far been able to accomplish. For us SO guys, torque management is a big problem. The rest of you guys don't have the same TM issues we do, so that doesn't really apply. If you want to daily drive a high HP SO rig, Smarty will make it more enjoyable I think once they tone down the throttle response a little.
As for settings for max power, every truck is different and will like different combinations. I can make a lot more power with a triple stack, each in moderation, than I can make with the BDDL/TST by themselves or the Smarty/TST by themselves. If I remember correctly, programmer on 90hp, EZ on level 3, and TST somewhere around 4/4 makes all out max power for me.
Old Sep 13, 2006 | 01:12 PM
BigDan's Avatar
I would'nt reccomend the Bullydog on a 03-04. I went for a ride in LCleary's truck and he "had" the BDDL and took it off in favor of the Smarty. He like it much better.
If he had a 04.5+ yeah get the BDDL with crazy lary but that program isnt avaiable for us 03-04.
Hey Lance if that Spike TV thing is a go you NEED to start a thread and tell these guys what your truck will need.
I think you should look into
*Stacks or single 6" stack so you dont smoke everyone out
*CP3 mods because your probably running your fuel rail dry
*Upgrade your TST with the new features
http://www.turbodieselregister.com/f...d.php?t=166202
*Valentine1 radar dectector....I have one and it has saved my butt countless times
*Some dyno time
Old Sep 13, 2006 | 01:44 PM
Luken's Avatar
Whats with the Spike thing? What does he need?
Old Sep 13, 2006 | 01:46 PM
*Some dyno time
Dude, I WANT to smoke them all out, sheesh! I definitely agree on the rest of the stuff, though. I have a Bel Electronics Pro detector, and it's every bit as sensitive, if not better than the V1. The only thing is it doesn't tell you what direction to po-po is coming from. Will probably get a V1 and run both - along with a scanner, cb, and jammer.
Old Sep 13, 2006 | 01:48 PM
On another note, I went for some rips around town with the Smarty on #8 (no timing) and the TST on 4/2. Holy crap it is FAST!
Old Sep 13, 2006 | 02:17 PM
wheelndealn's Avatar
My best was...
Smarty- 9
TST- 4/2
EZ- 2
but, I have a couple more mods, and a 05.
Old Sep 13, 2006 | 02:31 PM
Luken's Avatar
Originally Posted by wheelndealn
My best was...
Smarty- 9
TST- 4/2
EZ- 2
What were your numbers?
Old Sep 13, 2006 | 09:13 PM
blackmoke's Avatar
Let me know how the Smarty works out for you lmills
Old Sep 13, 2006 | 09:14 PM
I'm going to be racing Lamborginis and Ferarris across the US in the Bullrun cannonball run.
I need power. Lots of it!!!
Old Sep 13, 2006 | 09:54 PM
big shifter's Avatar
I have a TST early twins flash for03-06 for sale its is cherry I paid 799 ill let it go for 599
Old Sep 15, 2006 | 11:04 AM
Luken
786HP
1400+++TQ
