slow 02 with edge comp?
well I have an 02 that I put a comp on in ez mode and it seems to be slower than without, but it still puffs some smoke when i get on it, Also it runs great after 50 mph. Now let me tell u, the box is for an 01, so I just put an 01 map sensor in my truck and had a diesel shop make me the appropriate harness. I have been told the only differences in the map sensor are the plug design, So the only thing I can think of is that the made harness connections are not soldered together but twisted and taped, If thats not the problem what else could it be?
I got a comp in EZ on my 02 and ya can tell a difference , What sub level are ya useing ??? If your on sublevel 1or2 you wont feel anything till late in the rpm range. Sublevel 3-4 -5 youll feel it right away.
Well since its in ez mode I left the levels at 1 on both. The truck just falls on its face at 2500 and it just feels like a dog. But when I hit 50 or the truck pulls pretty nicely because it stays at a lower rpm. I guess it just isnt what I expected to be
my father inlaw has 00 huge response also is the fuel turned up on the box hold the power level botton 5 seconds let off tell flashing to see if all bars are flashing you can go to edge wed page to get info or call me 480-332-7343
well i moved the ground to the battery and it seemed to help a bit but the defueling seems to start so early and it doesnt have enough time to make power. I dont know it just irritates me because stock the acceleration from a stop seemed to be just as fast because the engine is working through the whole rpm band.
lvmknsmoke..
Nov 21, 2024 07:33 PM
13jy831
Feb 25, 2011 07:45 AM
mx684
13
Jul 24, 2007 07:52 PM
JD farmboy
May 21, 2006 01:04 PM
rockjeep73
Mar 25, 2005 03:34 AM
