single wheel spacer?
Old Sep 16, 2010 | 01:57 PM
Red_Angus's Avatar
did the brakes on my truck the other day and found a wheel spacer on the passager side. but not on the drivers side.
pulled it off, ran the truck for a bit and noticed that without the spacer there is a 3* gap in the steering system. put it back on and the gap disappeared.
has anybody else seen or had this done? both of my trucks have this modification. is it a bandaid or is there a better way to do it.
Old Sep 16, 2010 | 02:09 PM
Hodge's Avatar
Are your trucks lifted?
Old Sep 16, 2010 | 03:13 PM
Shovelhead's Avatar
Administrator / Scooter Bum
The spacer on one side was Dodge's "Fix" for a common complaint of "pulling while braking" in the early 2nd Gen trucks.
Old Sep 16, 2010 | 04:24 PM
97dodgeram2500's Avatar
my 97 has the same spacer on the passenger side i just leave it and dont mess with, but yes it was dodges way off fixing things, bs in my opinion
Old Sep 16, 2010 | 06:56 PM
infidel's Avatar
Many people have removed the spacer and noticed absolutely no difference.
Many times the spacer will get stuck to the back of the rim and moved to a different corner, again with no difference.
Old Sep 17, 2010 | 08:27 PM
Red_Angus's Avatar
im glad to see dodge has exceed my expectations again. is there an aftermarket fix to tighten the steering?
Old Sep 18, 2010 | 11:44 AM
infidel's Avatar
First you have to find where the play is.
#1 cause on 4X4's is a bad track bar.
This is also common> http://dodgeram.info/tsb/1997/19-10-97.htm
Old Sep 20, 2010 | 01:47 PM
high bid's Avatar
lol...yea I wondered 2yrs ago..what in the world is this goofey spacer and then read it was Dodge's "high-tech" way of correcting the steering pull during breaking.
Old Sep 20, 2010 | 02:17 PM
Red_Angus's Avatar
took the truck to a mechanic and he told me: new steering dampener and track bar. ball joints and only one of my tires is at replacement spec.
Old Oct 3, 2010 | 07:07 PM
dansdodgediesel's Avatar
I have the spacer also.
Put a Thuren track bar on and what made the biggest difference is the pitmit arm support bearing.
Dan
Old Oct 5, 2010 | 09:40 AM
Red_Angus's Avatar
have you guys tried the solid steel setup? or any other suggestions for track bars readily available. was gonna do my front end this weekend
Old Oct 5, 2010 | 02:43 PM
Backwoods Bumpers's Avatar
Vendor - Former Vendor
IMO, Thuren stuff is worth the wait. Top notch work.
misterKTM
Feb 11, 2015 01:21 PM
12valvin
Sep 15, 2009 12:05 PM
Towmaster101
Apr 10, 2009 12:12 AM
schorb
17
Aug 23, 2006 11:11 AM
ram350013
Jun 30, 2006 03:18 PM
