should i weld the exhaust or use clamps???
Old Apr 2, 2005 | 09:59 AM
bws's Avatar
bws
just bought a 4" rip system and am wondering if i should just mig weld everything after everything is fit checked and adjusted??any input?
Old Apr 2, 2005 | 10:19 AM
high country's Avatar
if you have access to a mig with .030 or smaller wire you can ensure a sealed system, if you are a bit sketchy on your welding leave it alone, there is not much steel to suck the heat out of your weld. In my opinion a welded system is the best as there is no way for corrosion in the joints as they are sealed, flip side clamps work good most of the time and let you take the system out, but how many times have you pulled your whole exhaust system out?
Old Apr 2, 2005 | 10:23 AM
oscaroc's Avatar
You can also just put a tack on each seam with the clamps in place and it will make your whole system more rigid
Old Apr 2, 2005 | 02:02 PM
P.O.R.'s Avatar
if you are thinking of welding just to seal it up use high temp silicone,works great.
Old Apr 2, 2005 | 05:14 PM
Cowhand's Avatar
Band clamps work great.....and I've had to remove various parts at different times. Dropping the front half made it easier to get the trans out.....
Never had a leak with the band clamps and it makes the exhaust a snap to take apart and put back together.
Old Apr 2, 2005 | 05:26 PM
ChrisLib's Avatar
thats how i put mine in, works great.
Old Apr 3, 2005 | 01:26 AM
Huff nPuff's Avatar
I agree with Cowhand
The stainless steel band clamps work well, if for any reason you need to move or adjust pipes you can.works better than welding or muffler clamps.
Old Apr 3, 2005 | 06:30 AM
ChrisLib's Avatar
Re: I agree with Cowhand
When I did put in mine, I at first just used band clamps, but for some reason the ehxhaust felt "wiggly", like the clamps were not tightening things up enough, so I took them back off, zapped a tack on ech joint and so far so good, the clamps don`t leak.
plakia
Feb 17, 2011 08:15 AM
Strong05
Jul 1, 2009 01:03 AM
dog rocket
Oct 16, 2007 01:05 PM
singleturnout
Feb 20, 2006 06:18 PM
clifford
Dec 14, 2003 03:38 PM
