KDP use JB weld?
Old Feb 16, 2011 | 06:36 AM
plakia's Avatar
KDP use JB weld?
A few years back I addressed the kdp by putting it back in with jb weld, no tab. Has anyone had any problems with it dropping back out after doing it this way? Should I have just left it out? Thanks for any input
Old Feb 16, 2011 | 07:08 AM
Don T's Avatar
I don`t know why you would take a chance like that with JB weld.I tab mine and I know it can`t come out and mess up the gears.I can now sit back and not worry about the KDP again.Its a bit of work to do and then wonder if you have fixed the kdp.
Old Feb 16, 2011 | 10:22 AM
infidel's Avatar
I would think the J-B Weld would just crack and be as good as nothing.
Simple and free way to contain the KDP if it's still recessed or can be pounded down below the level of the cover a little bit is to use a punch to peen over the edge of the hole a little bit.
You really only have to use a tab if the dowel pin is protruding.
Old Feb 16, 2011 | 09:09 PM
csa's Avatar
csa
i would have to agree when i did mine i used a tab cuz it was flush with back of case (inside) i would never use jb weld on kdp. its only going to break off then you have two pecies of debrie. sorry.
Old Feb 17, 2011 | 08:15 AM
jesussaves's Avatar
its easy to make your own tab out of a old bracket or piece of metal and a grinder and drill
whitepowertruck
15
Apr 4, 2014 04:14 PM
sootnsmoke
Jan 5, 2012 08:55 PM
Smokin96_12v
Oct 12, 2009 07:39 AM
dog rocket
Oct 16, 2007 01:05 PM
bws
Apr 3, 2005 06:30 AM
