Scotty II
Old Mar 19, 2004 | 09:04 AM
Junk Yard Dog's Avatar
Scotty II
Finally, the orders must be getting caught up. Should see mine next week.
Thanks Rod
Rick
Old Mar 19, 2004 | 07:35 PM
dodgediesel4x4's Avatar
Good to hear, I guess BigBlue shoud have his in soon also.
Old Mar 19, 2004 | 07:55 PM
BigBlue's Avatar
Mine's in. Just got to pick it up.
Old Mar 21, 2004 | 05:25 PM
herb's Avatar
what actual advantage is there for going from stock to scotty?
Old Mar 21, 2004 | 08:01 PM
herb's Avatar
Old Mar 21, 2004 | 08:27 PM
Herb, try a search for scotty system and all your Q's will be answered.
Old Mar 21, 2004 | 08:47 PM
Mcdowra's Avatar
drop in egt's
cleanable air filter
Old Mar 21, 2004 | 09:36 PM
Dr. Evil's Avatar
ccccooooollll air
Old Mar 22, 2004 | 12:30 AM
Got Smoke?'s Avatar
Well my truck had about 175 of them.........that was the degree's of EGT reduction I got with the cowl hole cut.
Old Mar 22, 2004 | 12:44 AM
BigBlue's Avatar
Going from stock to Scotty, you probably won't notice to much of a difference. If you've got some extra ponies under the hood, you'll notice a BIG difference in EGT's.
Old Mar 22, 2004 | 08:52 AM
Scotty's Avatar
Top's Younger Twin
I won't even suggest purchasing a Scotty II unless you are doing one or more of the following:
1] You are stock but tow heavy. 100F reduction
2] You are mildly modified and tow lots. 100-150F reduction
3] You are heavily modified and have addressed your turbo if its beyond its efficiency limits. 150-200F reduction and even higher depending on the trucks BOMBs.
I do not suggest the Scotty II for stock non towing trucks.
I think the cost outweighs the benefit and a BHAF or even a replacement panel filter would suffice until you are in the 350HP or higher range or the points listed above.
Old Mar 22, 2004 | 10:38 AM
herb's Avatar
i tow a lot not heavy but LOTS of wind resistance. have the ez edge
Old Mar 22, 2004 | 11:37 AM
BigBlue's Avatar
I'm putting the Scotty on my truck because of what I have planned for my truck later on down the road.
Old Mar 22, 2004 | 11:53 AM
AlpineRAM's Avatar
I can't comment on whether you'll benefit strongly or not- but one thing to be consiered is turbo noise or music. Depending on personal taste you'll hear more of one of the both with a Scotty 2 than with the stok air filter. IMHO the BHAF was somewhere inbetween stock and Scotty2 for sound levels.
I do like mine very much and wouldn't want to be caught without it.
AlpineRAM
Old Mar 23, 2004 | 12:42 AM
Got Smoke?'s Avatar
AlpineRAM
However a TAG will greatly reduce that turbo noise! I would venture to say my TAG reduced turbo noise by MORE than 50%.
hellotbone
Dec 9, 2003 12:32 PM
Stamey
Mar 18, 2003 04:09 PM
thecatsfan
15
Mar 14, 2003 10:21 AM
thepunkno1
13
Mar 12, 2003 07:55 PM
