Replacing my TST box
Old Oct 23, 2008 | 04:26 PM
R.O.D.P.99's Avatar
I've got a 99 4wd. 80hp injectors (150's in a few weeks), FASS system, high tech 64mm turbo of some sort, AFE stage 2 intake.. SBC single disk, Think that's it.. Currently I have a TST Powermax and I wanna get rid of it. It's only 80hp and it does stupid things sometimes. Suggestions on another box? I'd like a 100-160hp tune if that helps.
Old Oct 23, 2008 | 07:13 PM
Krob's Avatar
Quadzilla Adrenline the new hot thing. Probably the best thing out on the market. I think thats a 120+ a little box.
Also take what you just posted and put it in your signiture, so you dont have to repeat yourself.
Old Oct 23, 2008 | 08:44 PM
98.5Hotrod's Avatar
Why don't you upgrade to the TST Comp.
Old Oct 23, 2008 | 10:07 PM
kgspeed700's Avatar
agree with 98.5hotrod
Old Oct 23, 2008 | 11:18 PM
hink's Avatar
Agreed..........just call TST and talk to them, they should be able to upgrade your box and get you back in business. http://www.tstproducts.com/
Old Oct 24, 2008 | 08:47 AM
R.O.D.P.99's Avatar
I was told once that I could basically have the box flashed to a Comp? Is this true?
Old Oct 24, 2008 | 07:15 PM
mopar-or-no-car's Avatar
Ya I talked to them awhile ago and they said send it in with $50 and they would upgrade it to the comp, but mines a pm3 so I dont know if it would cost more upgradeing from a pm1 or not.
Old Oct 25, 2008 | 09:11 AM
Ph4tty's Avatar
Like they said at least try the comp upgrade. A timing box can help a bit to, anything from a power puck to a smarty, anything that advertises 60hp is going to complement the tst box. I run a smarty/ tst comp. The comp ugrade add more fuel, adds fuel at lower boost, and fuels further into the rpms also.
Old Oct 26, 2008 | 12:42 AM
jwb600's Avatar
the redline made by bluechip, new quad box or an edge drag box are the only mean ones I know of matt
Old Oct 26, 2008 | 08:10 AM
Ph4tty's Avatar
Yes those are all mean boxes, but then he'd have two fueling boxes. Those would all be good alternatives if he wanted something different, but with the competition upgrade and some extra timing the tst comp will hang with any of those hp wise. I don't even turn mine up past 1/2 way due to the lope its causing. Its just my setup and not everyone gets the lope, but I kind of like the fact that I can make it lope via remote control
Old Oct 26, 2008 | 01:59 PM
R.O.D.P.99's Avatar
I think I'll just get the box flashed, get the 160hp inj. I was planning and save for a d.d. clutch. Don't think the single will hold another 100-150 hp..
Old Oct 27, 2008 | 09:05 AM
jwb600's Avatar
add tractions bars to the list
Old Oct 27, 2008 | 12:05 PM
R.O.D.P.99's Avatar
Yeah, forgot that part, those too. Then head studs, then probably a new block.
Old Oct 29, 2008 | 11:36 PM
jwb600's Avatar
and a new fender, paint, tires etc haha
04ctd
Oct 5, 2006 08:27 PM
CmminsBeast
Jul 17, 2006 02:23 AM
whatdieseltoget
Nov 6, 2005 08:33 PM
Valv
Apr 10, 2005 04:58 PM
mx261
Mar 31, 2005 07:19 AM
