removing boost elbow
Old Oct 19, 2003 | 11:11 AM
More Power's Avatar
Why cant you take your elbow out of the turbo and just plug the housing with a pipe plug?
Old Oct 19, 2003 | 11:25 AM
Re:removing boost elbow
You can, but you'll probably have more boost than you need which will hurt the power. With enough fuel you'll be able to overboost the turbo and kill it. I wouldn't recommend disabling the wastegate entirely. Get an adjustable elbow or a Turbo Master.
Old Oct 19, 2003 | 11:31 AM
More Power's Avatar
I did this because i was only seeing about 26psi at wot with ez and 275s shouldnt it be higher . Pluged it produces 35psi
Old Oct 19, 2003 | 06:43 PM
35 psi won't hurt it. The wastegate was limiting your boost before. Did your EGT's go down?
Old Oct 19, 2003 | 07:26 PM
More Power's Avatar
My egt get about 1300 and thats running wot up through all the gears. How much boost at this set up is too much boost?Thanks for the info.
Old Oct 19, 2003 | 09:11 PM
dodgeram's Avatar
I've got a comp and 275's with the elbow ...........I get 38lbs of boost
dodgediesel
14
Dec 14, 2006 09:54 AM
TorqueJunkie
15
Aug 30, 2006 09:15 PM
RockcrawlingTJ
Jul 22, 2006 05:11 PM
triplenickel
Aug 23, 2005 04:01 PM
Palmetto_kid
Jan 16, 2004 02:21 PM
