Quick DTT trans question
Old May 18, 2005 | 09:33 PM
2k1yzfr1's Avatar
Would a trans out of a 01 4x4 bolt right on to my 98 4x4?
Old May 18, 2005 | 11:34 PM
mr T's Avatar
i think so...they're both 47 re's i dont see why not....but its electronic i dont know how complex all that wiring would be
Old May 19, 2005 | 12:36 AM
AlpineRAM's Avatar
That's a tricky one. I assume there would be no problem, but I'd call DTT and ask them.
AlpineRAM
Old May 19, 2005 | 07:12 AM
j-fox's Avatar
The question will be, is it set up for the 98 correctly. Most of them are calibrated and set up for the application.
Old May 19, 2005 | 10:02 AM
RowJ's Avatar
Are they both 47RE's...I thought all 12v auto trannys were hydraulically controlled ??
RJ
Old May 19, 2005 | 10:08 AM
Tmc243's Avatar
My 97 has the 47RE. I'm not positive but I think the 47RE goes back to 1994. The electronics may be different though.
Old May 19, 2005 | 11:15 AM
gunracer1's Avatar
94 to 96 have 47rh i belive. call dtt and make sure the valve body is the same.
Old May 19, 2005 | 03:37 PM
HOHN's Avatar
I believe this ^^ is correct. Some later 12v have the RE.
jlh
Old May 19, 2005 | 03:40 PM
RustyJC's Avatar
My 1996 V-10 3500 had the 47RE. I think the 47RE was introduced in the 1996 model - 1995 and earlier were the 47RH.
Rusty
Old May 19, 2005 | 03:48 PM
Mcmopar's Avatar
Rusty - you got it 94-95 RH 96-2002 47RE and some 03's.
Old May 19, 2005 | 04:33 PM
cumminsdriver635's Avatar
What he said ^^^^^^
94-95 47rh
96-some 03's was 47re
Eric
Old May 19, 2005 | 06:02 PM
condensr's Avatar
Yep, my 96 has the RE as well.
The RE is not that well suited for the 12v applications, IMHO. They shift very early. This is apparently due to the fact that the computer (controlling the shifts) has very little data from the engine as to what is going on (e.g. MAP etc) on the 12v, therefore is not able to control shift points as accurately as on the 24v engines. I was told this by Dave Goerend when discussing my 96.
You should be able to make it work, but it might require some programming..? I'd call up DTT and ask them.. They'd be the ones to answer your question. Also, if you know who you're getting it from, they might remember the specifics on that particular tranny build and be able to give you some advice. They did just that on a DTT tranny I was considering buying used and I'm glad they did, as I didn't buy the tranny because of what they told me about how it was set up and being used.
Old May 24, 2005 | 10:41 AM
Eskimo's Avatar
The '01 tranny will have a slightly different setup in the valve body for the 24v's higher revving nature.. You might like it though... I think my tranny shifts too early, but it's good for keeping EGT's down.
Worst case, just get a 12v valve body, and you *should* be good, but a call to DTT would be prudent.
Oh, forgot to add... we had this problem on mine... some of the fittings, plugs, etc. on the outside of the trans. may be different, so keep your old tranny handy to swap pieces off of.
HorseHauler
13
Mar 12, 2006 11:48 AM
dukeboys
Jan 22, 2004 10:04 PM
dukeboys
Jan 12, 2004 09:26 PM
hellotbone
18
Jun 25, 2003 01:16 PM
Chrisf
Jun 25, 2003 08:56 AM
