Question about Edge Comp
I just purchased the upgrade from Edge EZ to the Edge Comp,,
I have a FP gauge and am going to get a pyro gauge,The comp will be here before the gauge,so you know I will install right away.
My question is what level can I put the comp on where the EGT's will not hurt anything?till I can install gauge I am not tapping the pump wire right now(203000 mile VP).
Maybe after I replace the IP i'LL tap it.
My engine is all stock except for a drop K&N
If youve got good fuel pressure i say go ahead and tap the wire, and cross your fingers. Even some fairly new VPs have been known to bite the dust with a tapped wire. Tapping the wire makes a huge difference in power, if your pump can survive
Yes, as long as you dont pierce the pump wire, you want be seeing much more HP over your EZ... When you do plan on piercing the wire, check out those new Stealth Covers. I cant remember who makes them, but Im sure someone will chime in and tell you. They make the connections to the pump more reliable!!!
Don
Don
Don
Don
-SFB
Blue chip diesel also makes a cover.
As for tapping the wire, Go ahead and do it. It is all hit and miss with the wire tap and the VP. If it is going to die, it will die really quick, It it lasts the first week, it will more than likely last a long time.
Just be prepared to fork out 1200-1700.00 if you tap the wire. But they are right...the Comp untapped is the same as an EZ.
As for the EGT's, I wouldn't go past 2x2 if it were me without a guage.
If you're not towing or hauling heavy, I don't think EGT's will be much of a problem if you stay smart about it. Even with my setup now, I don't have much EGT concerns in reg driving and playing around for a short time.
lvmknsmoke..
Nov 21, 2024 07:33 PM
13jy831
Feb 25, 2011 07:45 AM
mx684
13
Jul 24, 2007 07:52 PM
JD farmboy
May 21, 2006 01:04 PM
rockjeep73
Mar 25, 2005 03:34 AM
