Q? does the airflow system downpipe exit straight back?
Old Dec 13, 2002 | 10:12 PM
patriot pearl blue's Avatar
http://shop.airflowonline.com/Mercha...egory_Code=DCE<br><br> i was wondering if anyone here has used the Air Flow Systems downpipe and single piece exhaust tailpipe??<br><br> im thinking of buying the tailpipe and downpipe but was wondering if they are parallel with the underside of the truck??<br><br> by looking at the pics, it looks as if they would be pointing straight at eachother when mounted on the truck-<br><br> and the muffler shop could weld in the rest of the pipe to complete the exhaust system.<br><br> any advice?? i couldnt find anything by using the search function-<br>thanks<br>bryan
Old Dec 14, 2002 | 11:13 AM
Re:Q? does the airflow system downpipe exit straight back?
<br> i just want to know is-<br><br> where the downpipe ends, is it going to be pointing straight back or angled toward the ground some?? <br><br> cause i dont think that the muffler shop will be able to bend 4 inch pipe, plus, i dont want to have non mandral bent pipe under the truck.<br> <br>TIA<br>bryan
Old Dec 14, 2002 | 06:17 PM
dodgeman01's Avatar
It will be pointing straight back twards the rearend. they have it upside down in the Pic on there site.<br>DM01
Old Dec 15, 2002 | 12:10 AM
Cummins4u's Avatar
I put one on my truck. The pipe points slightly in the direction of the drive shaft. I tried to get it to go straight back but the pipe will hit the frame rail. It exits within the transmission crossmember. The pipe you put behind it will require a bend or I guess you could get out a BFH and dent the pipe where it hits. ;D I just have a piece of pipe to clear the crossmember and a turndown on mine. Sounds pretty good. People give me dirty looks when I pull under the canopy at the bank drive thru. Seems they get me done first so the can see and hear the other people.
97catintenn
Jul 12, 2009 05:33 PM
sleeper-sport
Aug 5, 2008 12:14 PM
dieselfuelonly
May 26, 2007 07:04 AM
dieselfuelonly
May 25, 2007 12:03 PM
GO 4LO
13
Jan 14, 2005 12:54 AM
