Pyrometer????????
Old Mar 5, 2003 | 06:50 PM
GaCamper's Avatar
Pyrometer????????
Does anybody know where I can get a Pyrometer for my 5.9 Cummins without having to give a arm & a leg for it? Also what does it take to hook one up? I take it you have to drill and tap a hole into your exhaust. Just wondering if it works well without any problems of leaks or blowing out of the hole? Any suggestions are welcome! Thanks
Old Mar 5, 2003 | 06:56 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Re:Pyrometer????????
I got mine from www.wildcatdiesel.com
Good Pyros ain't cheap. The Cummins is a $4000+ option.
They have to be precise to keep you from having to hang a bucket on the end of your tailpipe to catch the melted aluminum from your pistons.
Mine's been in for over a year, pre-turbo, no leaks.
Just take your time and measure twice.......drill once.
Ed
Old Mar 5, 2003 | 06:58 PM
C4L's Avatar
C4L
Give Rip a call 1 (866) 211-1533
I have mine pre-turbo with no problems.
Old Mar 5, 2003 | 07:02 PM
boehunter49's Avatar
Hay I got all my gauges from TST. there prices arn't bad an the service is super. As far as installing the pyro it is a simple operation yes you drill an tap a hole in the manifold (use a lot of grease on the drill an the tap ) it keeps chips from falling down inside, also a little pencil magnet to probe around in there after the hole is drilled.<br> All in all this is not a bad job.<br> Bob ;D
Old Mar 5, 2003 | 07:33 PM
GaCamper's Avatar
Thanks for the info...It's time to go looking!
Old Mar 6, 2003 | 07:46 AM
TPilaske's Avatar
E-Gauges has some pretty good prices too! <br><br>Tony
Hummin Cummins
24
Feb 24, 2003 10:35 AM
Homestead
Feb 9, 2003 03:14 AM
adgr71
Jan 14, 2003 01:07 PM
Push Rod
Oct 22, 2002 10:04 PM
