"A" Pillar Gauge Pod
Old Jun 12, 2003 | 01:59 PM
Iron Horse's Avatar
How is everyone securing their "A" pillar gauge pod? I have had my gauges and pod in for a while now, but it still isn't mounted securely. I have a pro pod that was supposed to be a cover, but I am using it as a replacement. Any info or pics would help. Thank you.
Old Jun 12, 2003 | 03:31 PM
Diesel Dave's Avatar
Re:"A" Pillar Gauge Pod
I drilled a hole in my gauge mount and put a screw through it into one of the holes in my A pillar near the top. It holds well and has never come loose. The dash hold the gauge mount tight at the bottom.
Old Jun 12, 2003 | 07:06 PM
GlennO's Avatar
Iron Horse I jsut finished putting mine in <br>here is a picture notice the screw jsut above the top gauge<br>seems to work good
Old Jun 13, 2003 | 07:48 AM
redramnc's Avatar
I am running a three-pod A pillar mount and have had no vibrations or any other problems over the last year and a half. I am holding it in with a TEK screw up top and just friction fit down low. I painted mine to match the original gray pillar cover and nobody can tell its not stock, except for the trans temp, EGT, and boost guauge straring at them. ;D
Old Jun 13, 2003 | 08:24 AM
TXRAM2's Avatar
IronHorse, like said above seems to be the popular way. I did mine that way but put a lower screw in also. I too didn't want to butcher the factory pillar.
Old Jun 13, 2003 | 01:34 PM
Iron Horse's Avatar
I was tryin to come up with a way to not have any visible screws, but it should look OK if I paint the head to match. <br><br>Thanks a lot for the help.
Old Jun 13, 2003 | 02:29 PM
TPilaske's Avatar
I have mine held up with Velcro strips... it's been good for over a year... ;D<br><br>Tony
Old Jun 13, 2003 | 02:56 PM
OlBlue's Avatar
I used Goop ABS glue to hold the pod onto the factory cover. VERY professional and factory in appearance. <br><br>It does take two days to fully cure, but I was willing to be patient for the appearance.
Old Jun 14, 2003 | 12:04 AM
Iron Horse's Avatar
Well I decided to use 2 screws toward the top of the A pillar, I picked up some nylon spacer tubes to use to get the spacing just right, and am going to countersink the screws and use black caps to cover them.<br><br>Hopefully it won't look too bad.
TxDiesel007
May 9, 2006 10:36 AM
I PASS GAS
Mar 16, 2006 07:59 AM
NCLandscaper
Dec 19, 2005 12:43 AM
timk006
15
Sep 9, 2005 11:34 AM
5.9thatsmokes
Feb 25, 2005 10:09 AM
