Curiosity about FP gauge mounted on A pillar triple pod
Old May 8, 2006 | 02:05 PM
TxDiesel007's Avatar
Guys
the first thing ima do when i fill my piggy bank for the "toy" fund i have at home is plain and simply order some gauges. Ive been lookin at the Isspro gauges that pretty much look stock on my truck, I want to keep that matching look on the A pillar
I know that many of you guys run FP guages on a 12V, and i wanted to know if it was possible to just route the lines to the bottom of the triple pod and go ahead and just run the gauge with no leaks? i want to have FP at the top, pyro in the center and the boost at the bottom,
if i do go this setup, would it jsut be easier to put the FP at the bottom to minimize running lines? I want it at top cause it would be the one that i look at the least.
Now i already have gauges, but they are inefficient for my use and the pyro is post turbo...
I want to redo them and do them right... if anyone has pics of this setup please let me know, any and all opinions are welcomed....
Here are the ones that i want..
http://www.genosgarage.com/CoastalDa...ID=817&CATID=1
http://www.genosgarage.com/CoastalDa...D=1753&CATID=1
http://www.issproinc.com/proddetail.php?prod=R5604 (they make this one with the red pointer to match the other gauges in a 60 lb gauge)
(PS my clutch fund is still seperate )
Thanks guys!
Rick
Old May 8, 2006 | 02:21 PM
BigBlue's Avatar
Shoot yeah. I run a line from my injection pump straight up to my FP gauge with nothing more than a needle valve in between. My FP is mounted on the third pillar.
P.J's Avatar
P.J
I ran mine down bottom just on account of what you are taling about. I just wanted to the hose to route as smooth as possible. If it's gonna leak, it's gonna leak no matter where you put it.........
Old May 8, 2006 | 02:55 PM
WideOpenThrottl's Avatar
Txdiesel007,
your going to want a gauge that goes higher than 30psi, I believe that idle pressure can be around 35psi on the 12valves, I may be wrong but I'm pretty sure that its over 30psi at idle.
Tim.
Edit, just read this, nevermind,
Old May 8, 2006 | 03:09 PM
CTD NUT's Avatar
I had no trouble running a 4 AN line to my FP gauge and yes, it is mounted at the bottom of the triple pillar for specifically the reason you mentioned.....it would be very difficult to route that line past the bottom mount in the pillar.
Old May 8, 2006 | 04:56 PM
Willy91's Avatar
No problems at all running it to the cab rick, mines run to a pod under my dash but you can run it to the a pillar just as easy
Old May 8, 2006 | 08:25 PM
Thanks guys!
wonderin what id do without yall expertise..... I still amaze myself how much i learn here from all of you...
Rick
Old May 9, 2006 | 08:50 AM
Mark Craig's Avatar
TxDiesel007,
Lots of guys just run a line, but I strongly reccomend that you use an isolator as it keeps fuel out of the interior and if you get a pancake style like we sell it will be trouble free, some of the old cylinder style were problems etc.
Mark @ DPPI
Old May 9, 2006 | 09:53 AM
P.J's Avatar
P.J
Gauge = $35.00
Gauge + Isolator set up + stainlesss hose = $140.00 +/-
Old May 9, 2006 | 09:56 AM
Mark Craig's Avatar
P.J,
If you want a stainless hose it is expensive but not necessary. The hose we use is good up to 400 PSI made by Goodyear and is very cost effective. Approx 25% less than you mentioned depending on what options etc.
Mark @! DPPI
Old May 9, 2006 | 10:36 AM
P.J's Avatar
P.J
Originally Posted by Mark Craig
P.J,
Mark @! DPPI
I was estimating the difference between a straight mechanical set up v.s with isolator.
I sheathed my fuel tube in the next size fuel hose from NAPA. It seems like most of these hoses are waaaay overkill. I figure that if you are 300% over, you are doing just fine (~50psi).
Just my opinion.
bryson711
Aug 16, 2015 12:40 AM
bob95065
Jun 25, 2012 10:08 AM
darrenb
Mar 20, 2007 10:19 PM
CARR
Feb 8, 2007 12:04 PM
wcbcruzer
Apr 18, 2005 12:01 PM
