Aftermarket tweeters for aftermarket a-pillar gauge pod
Old Mar 14, 2006 | 08:04 PM
I PASS GAS's Avatar
So here's the deal. I put bought a pair of Rockford Fosgate components for the front of the truck. I put the tweeters in the a-pillars and had to cut the holes larger than the factory ones.
Now I bought gauges and the pod for the gauges on the a-pillar have a location for the tweeter, but the dang tweeters I have are too large to fit in the pod. The hole in the pod is 1 3/8", and cannot be cut any larger. Do any of you know of any GOOD tweeters that will fit this size hole? I'm dieing to put in my gauges, but don't want to put them in until I have the tweeter situation nailed down or I know myself and I'll end up tweeter-less for a year.
Old Mar 14, 2006 | 10:31 PM
ratsun's Avatar
I glued mine in behind the factory grill. They are about 1/4 inch bigger (MB Quart Qline) than the hole when you snap the grill out. If you mount them in behind the grill just make sure you seal them up tight to the inside of the pillar so all the sound comes out of the grill and not into the pillar. I usually start with a hot glue gun to hold them in place then run a bead of RTV silicon around to do the sealing and mounting.
Old Mar 14, 2006 | 11:05 PM
Timmay2's Avatar
I glued mine in.
Not a perfect fit but oh well.
Well see how it last come 120 degree AZ summer.
Old Mar 15, 2006 | 12:03 PM
Mike D's Avatar
JL makes a 3/4 " tweeter. Very nice sounding. It's engineered by the guy from MB Quarts.
Old Mar 15, 2006 | 08:03 PM
I PASS GAS's Avatar
Would you happen to know the model number of them?
Old Mar 15, 2006 | 08:36 PM
chaos24valve's Avatar
THis may not be any help, but I got my Pioneer 5 ways on overstock and they completely cover the sound from the factory tweeter. They sound just as good because you have all the stuff for it...I like them Just a suggestion. Plus the silver looks really cool in your door panel.
Old Mar 15, 2006 | 08:52 PM
I PASS GAS's Avatar
I appreciate the suggestion, but I already have the pod w/tweeter AND the component speakers. Its pretty much too late to turn back now.
Old Mar 16, 2006 | 07:59 AM
Mike D's Avatar
I bought them as a componet set. The model number is VR650.
wcbcruzer
Feb 13, 2008 10:12 PM
MoparNut
14
Oct 13, 2007 06:38 PM
ajpulley
13
Aug 7, 2006 04:42 PM
chucktownsend5
Jan 22, 2005 07:15 PM
Iron Horse
Jun 14, 2003 12:04 AM
