PDR vs Helix Cam?
Old Dec 19, 2006 | 04:56 PM
  #31
signature600's Avatar
Don, I'm still trying to figure out how your cam build boosts at idle on a turbo charged engine.
I thought I saw something like this too, but I can't find it now! Also, I don't think he meant idle...I think it was in neutral "free-revving" the engine!
As far as the gear walk...saw it on tractors, makes a mess. That's why I consider the bolt on gear not only as an Upgrade, but as cheap insurance too! Yes, it could still happen, but at least I did my half to try and beat my normal luck
Chris
Old Dec 19, 2006 | 04:59 PM
  #32
Don M's Avatar
DTR Advertiser
I wish it would do that at idle! You need some RPM first, like around 2500-3000 and a small turbo like the stocker on the 04.5 and up. LOL
Old Dec 20, 2006 | 02:55 PM
  #33
Mike Holmen's Avatar
The Guru
Don, I had my visa card ready if your camshaft made boost at idle. It sure would fix my smoke trails. You must be running a faster ramp rate than the stock cam to create that much valve spring heat and binding. I can see that helping the engine to breathe more, I'm supprised that cummins hasn't done something similar but its more than likely for emmission.
Old Dec 21, 2006 | 05:30 AM
  #34
gsdog1's Avatar
Chris
Howdy Chris (and all the rest)!
That would be me, most likely, as I posted results like this a couple of times. With the stock charger on this truck plus the cam, and free rev'ing the engine in neutral, I could put ~17 psi on the boost gauge. With the twins, I can put 5 to 7 psi on the gauge.
And as my 4 year old would say, "it's just flat silly!"
Old Dec 21, 2006 | 07:19 AM
  #35
That's who I thought it was
BTW, you're old clutch made it 95K miles before an overhaul...and it had about 20K more to go, before I messed up the hubs
Chris
etn550
Apr 1, 2010 12:12 PM
Gabe32
Mar 21, 2007 07:22 PM
06dmc
13
Oct 9, 2006 11:25 AM
More Power
Jan 1, 2006 12:08 PM
Timinva
18
Dec 7, 2005 05:06 PM
