Head Work
Old Dec 20, 2006 | 08:16 PM
Hoob's Avatar
Head Work
Just got my tranny rebuilt and was wanting to get some 150 hp injectors. What type of work should be done to the head gasket? Thanks
Old Dec 20, 2006 | 08:34 PM
blackdiesel's Avatar
Registered
you won't need head work till you get a great big turbo or twins, you will have some egt problems with the stock turbo.
Old Dec 20, 2006 | 08:56 PM
98.5POS's Avatar
Do you have the head off? What other mods are you planning? I ask because this is a critical time depending on where you want to be.
Old Dec 20, 2006 | 09:06 PM
Hoob's Avatar
I''ve got a drag box and am planning on getting a fass. The injectors might be all I do for a little while. I was planning on installing some new head bolts possibly.
Old Dec 20, 2006 | 09:13 PM
98.5POS's Avatar
IMO if you're ever going to consider twins or boost over 50psi I would put in studs and o-ring the head. If not I would at least put in studs, you can get ARP's from www.summitracing.com for about 425.00. They have at least twice the clamping force of regular head bolts.
Old Dec 20, 2006 | 10:08 PM
Registered
you need a turbo worse than you need studs
wastegate it back to 43 psi and run it till she blows, then redo your head
Old Dec 21, 2006 | 01:54 AM
Ph4tty's Avatar
You mean 34??
Old Dec 21, 2006 | 07:23 AM
Registered
Originally Posted by Ph4tty
You mean 34??
who me? ya 34-36 with a stocker, but if he upgrades 43 would be peachy
cheese4420
Apr 13, 2008 11:50 AM
96_12V
Jul 7, 2005 11:26 PM
Meatball
Feb 6, 2005 12:45 PM
PapaSmurf
Dec 18, 2003 10:47 AM
