Not building boost
Old Jun 11, 2024 | 09:26 AM
ThatSlowVP44's Avatar
Not building boost
are 100hp injectors enough to fuel a 63/68/12 if they are any suggestions on where to check because I can barely build up to 20psi of boost
Old Jun 11, 2024 | 09:57 AM
The year and some general info on your truck would help.
Are you sure you do not have a leaking intercooler or a hole in an intercooler boot? Or maybe a loose clamp?
Old Jun 11, 2024 | 10:55 AM
Sorry about that when I updated my profile I thought it would show here but I have a 2001 with a 63/68/12 smeding turbo 100hp 7x.010 injectors a super chips cortex tuner a fass 150gpm a hot rod vp44 and a K&N cold air intake along with glow shift gauges and the man who had it before me bored it out slightly but I’m unsure if that would affect anything
Old Jun 11, 2024 | 11:04 AM
Sounds like you have plenty of fuel to boost things well past 20 PSI at WOT.
Start by looking for leaks. The two lower boots at the intercooler. tend to get worn through by the inner fender on the 2nd gens often.
Old Jun 11, 2024 | 12:04 PM
Ok, would it be possible that it is also a boost fooler issue as I’m unsure if the cortex tuner I’m using has one.
Old Jun 11, 2024 | 12:43 PM
What do you mean? A boost fooler that actual doesn't have to fool your motor, because your actually not building much boost?
I am assuming you are using your Glow shift gauge that is mechanical and will read the pressure the motor is actually getting.
Old Jun 11, 2024 | 01:44 PM
Just finished checking and I couldn’t find any leaks in my piping
Old Jun 11, 2024 | 01:52 PM
How did you check it?
Old Jun 11, 2024 | 02:37 PM
Yes I was using the glow shift gauge and I checked it with soapy water and a air compressor
Old Jun 11, 2024 | 02:42 PM
Did you check in the intercooler for leaks too?
Also you might want to check the waste gate on the turbo is working.
Old Jun 11, 2024 | 03:20 PM
The wastegate is functioning and per smeddings website it set from 36-40 psi from factory so I’m thinking it’s something electronically wrong but I’m not sure what could be the issue
Old Jun 11, 2024 | 04:37 PM
Does it make any smoke under WOT?
Have you checked the fuel filter?
What is the fuel pressure at the injection pump?
Old Jun 11, 2024 | 06:09 PM
It does smoke before WOT depending on how it’s being drove and fuel filters were recently replaced currently waiting on a adapter to come so I can get a fuel pressure reading
Old Jun 13, 2024 | 08:34 AM
cougar's Avatar
After going to Hollie's Superchips web page and found no match, I'd suspect you may have the wrong tuner. Also, I wouldn't trust a Glowshift gauge to be anywhere near accurate. Just my experience. My cheap pathetic Hyperchips Max Energy bumps it up enough to keep throwing an over boost code. Stock engine except I replaced the HY turbo for an HX.
MikeyM
Aug 24, 2007 11:51 PM
CTD01
Jun 25, 2006 04:27 PM
StevenB05
Jun 29, 2005 04:48 PM
