neeed help fast on edge comp install...
Old Mar 20, 2005 | 04:29 PM
bws's Avatar
bws
ive got two wires i dont think i should hook up till i get my secondary lift pump, the red one to the vp 44 and the ground wire.is this correct or should the ground be hooked up???i was going to order a cover to hook up the fuel wire but i,m not sur about the ground wire.???
Old Mar 20, 2005 | 04:32 PM
BigBlue's Avatar
Hook up the ground. I have mine on one of the intake elbow bolts. There should be a grey wire for the VP44. The red wire goes to a power source.
Old Mar 20, 2005 | 05:02 PM
ratsun's Avatar
BBlues givin it to you straight
Old Mar 20, 2005 | 07:03 PM
paulb's Avatar
Hook up the ground...but hook it to the negative of the battery rather then to the air horn. Believe it or not the air horn is not always a good ground.
Old Mar 21, 2005 | 10:11 AM
bws's Avatar
bws
good idea,i drove it with the comp on[no wire] and it didnt seem to do much??i want toorder a complete fuel system[bd@260.00 or fass or??}will order the tst grabber wire right now.i need recs on a added pusher!!!!and injectors.will go to rip for the exhaust.just a little more help guys...thanks
crewcabxlt
Mar 24, 2010 07:45 PM
manureman
Feb 27, 2007 07:56 PM
JD farmboy
May 21, 2006 01:04 PM
24valver
Mar 6, 2006 07:19 PM
rockjeep73
Mar 25, 2005 03:34 AM
