Max Boost = 29 psi
Old Feb 26, 2007 | 12:43 PM
Big Blue24's Avatar
Max Boost = 29 psi
Does this sound a little low? I can't hit over 1150 on the pyro either! I have new injectors on the way, but for now, just whats in my sig and Juice set at 5x5. Do you all think my Map sensor could be weak since i'm getting my boost numbers from the Attitude monitor?
Old Feb 26, 2007 | 12:44 PM
BigBlue's Avatar
For just a juice and nothing else your right around the safe point. I usually like to see around 35psi out of an HX35 but 30 is fine.
Old Feb 26, 2007 | 12:45 PM
Big Blue24's Avatar
Side note: The weather is cold, like 25 degrees but I am at 4500' elevation, and tomorrow i'll hit 6500' and see how much boost i can make. I'm just worried my turbo might be biting the dust due to my Nitro Methane Runs!!
Old Feb 26, 2007 | 12:50 PM
BigBlue's Avatar
It's a possibility.
Old Feb 26, 2007 | 12:54 PM
JD Dearden's Avatar
I would probably have to say that your biggest problem is the fact you live in Provo.
Old Feb 26, 2007 | 03:10 PM
Big Blue24's Avatar
Just for school, I don't intend to live here ever again. Too many do gooders, too many nice people, too many beautiful girls! I like it here, just don't want to work in this market!
Old Feb 26, 2007 | 11:51 PM
Ph4tty's Avatar
Better check for codes Did you change the oil or run analysis on your oil after the nitro?
Old Feb 26, 2007 | 11:59 PM
BCSCUMMINS's Avatar
I hit 48psi with my stock HX-35
Old Feb 27, 2007 | 02:28 AM
Big Blue24's Avatar
You also have injectors, I'm pretty much stock except for the box and a supporting things. No, I didn't do the oil analysis yet, I will however do it soon as i need an oil change right now.
Old Feb 27, 2007 | 08:17 PM
Big Blue24's Avatar
I just hit 30 PSI at about 6000' elevation. But that was WOT for 20 seconds on a hill in 5th gear and Juice 5x5. This Juice sure smokes a lot more than my comp did, if I take off in second with no go petal and then floor as soon as I'm rolling... I can make the vehicle behind me disappear. It almost makes the truck lope like it quenches the fire or something. I swear that with a boosted launch, the Juice pulls harder than my comp, but from a lugged start, the comp would pull harder. And the Comp definately pulled harder in the middle but a little weaker on top. Weird... I'd say that If i had an auto, the comp would be faster due to it's middle power, but the juice is definately faster on my 5spd.
Old Feb 27, 2007 | 08:27 PM
Muddin_dude06's Avatar
The Juice might feel slower off the line because it throws in so much fuel it begins to put out the fire...? The comp may have had a more "tame" low-end fueling curve...
Old Feb 27, 2007 | 08:56 PM
12valve's Avatar
i have a drag comp, n my 01 at around 6000 feet elevation, it makes only 30 psi max, with a plugged wastegate... (analog guage)
Old Feb 27, 2007 | 09:35 PM
sluggo42's Avatar
I pulled 33 psi today on #5. The best I got on #2 was 25 psi
Old Feb 27, 2007 | 10:34 PM
dieselrob's Avatar
When i only had the comp only i could get 36psi steady on wot at 1100ft or less.
Old Feb 28, 2007 | 02:23 AM
Big Blue24's Avatar
I will install my new injectors on Sat. Maybe with some RV's I can finally hit 35 psi.
Brad5502
Dec 23, 2011 05:02 AM
dieselboy59
22
Jan 2, 2008 10:29 PM
PowerDually
May 31, 2007 04:55 PM
ckennedy
Sep 29, 2004 05:06 PM
redhornet
Jun 18, 2004 09:26 AM
