Boost max's out at 21 psi - normal?
Old Dec 18, 2011 | 11:31 PM
Brad5502's Avatar
With the truck in my sig, I never get above 21psi on the boost gauge, even with the Smarty on level 5.
Is this normal.
If not, how does one find leaks?
Old Dec 19, 2011 | 01:01 AM
HMX-1's Avatar
Perfectly normal. The '03 has a manual wastegate, where the newer 3rd gen trucks are electronic. This is why even with the Smarty you won't get more than 21 lbs of boost.
Try using Google or search on here for "boost elbow", which is a way to manually set your wastegate so you can get more boost .... just be careful how much boost you end up dialing in, and make sure you have a boost gauge.
-Kris
Old Dec 19, 2011 | 09:29 AM
MikeyB's Avatar
Kris is correct. 21-24 psi normal for the '03-04 models. Get a adjustable boost elbow off of ebay that's preset to 32 psi. Anything higher than 32 psi super heats the little HE341 turbo with no additional gains other than killing the turbo.
MikeyB
Old Dec 19, 2011 | 08:09 PM
Brad5502's Avatar
Thanks for the quick replies. Found adjustable elbow.
If I set to 30-32 will it noticeably lower EGTs and increase power towing on hills?
Any downside?
Old Dec 20, 2011 | 07:25 AM
1-2-3's Avatar
Just a plain ole guy
If your working your turbo more, I think you'll see increased egt's
Old Dec 20, 2011 | 08:35 AM
MikeyB's Avatar
Yes, it will make a difference in EGTs with the additional boost. I cranked my Smarty down to level 1 when towing and my EGT's is less than 1000 degrees.
MikeyB
Old Dec 21, 2011 | 09:42 PM
Brad5502's Avatar
Excellent, I'll order one and give it a try.
Thanks for the feedback...I love this forum!
Old Dec 23, 2011 | 05:02 AM
Dodgezilla's Avatar
You could also just go to Home Depot and get a $.50 C-Clamp and put it on your wastegate hose. That's what I did. Does the same thing....
Tommy93w350
Aug 7, 2007 12:15 PM
PowerDually
May 31, 2007 04:55 PM
Big Blue24
14
Feb 28, 2007 02:23 AM
ckennedy
Sep 29, 2004 05:06 PM
redhornet
Jun 18, 2004 09:26 AM
