enough fuel pressure
Old Feb 27, 2007 | 07:16 PM
dustyman440's Avatar
Question enough fuel pressure
just installed my westech fuel pressure gauge . i have 13 pounds pressure at idle and 6 pounds at wot.is this normal for a stock lift pump? i also changed the fuel filter so i would get a good reading.
Old Feb 28, 2007 | 12:02 AM
WildBill's Avatar
it's a bit weak, would be better to see it up closer 8-10 psi minimum. Changing to high flow banjo fittings would help, unless you are eventually going to put in a FASS or similar.
Old Feb 28, 2007 | 01:54 AM
Big Smoky's Avatar
Do a Vulcan Relocation Kit. My FP is 15@idle and 8@WOT with a stock Carter.
Old Feb 28, 2007 | 02:41 AM
Geico266's Avatar
Monitor guages for trends in readings. 13 PSI idle / 8 PSI WOT is now your baseline, watch for changes.
marksblaster
Nov 4, 2012 08:02 PM
lu798welder
May 10, 2010 09:48 PM
roughstock
16
Mar 25, 2009 10:04 AM
novahauler
Aug 25, 2008 11:46 AM
Boatnik
Aug 5, 2007 09:09 PM
