K&N air filters?
Old Sep 1, 2006 | 06:26 PM
daysel's Avatar
K&N air filters?
The truck I just bought has one on it. I heard they are not good for diesels because of the oil on them.
True/False
Any gains by switching to a BHAF, or should I just not spray the oil on it?
Old Sep 1, 2006 | 09:06 PM
scottsjeeprolet's Avatar
Sell it on Ebay like i did and get the BHAF and still have left over money.
Old Sep 1, 2006 | 09:16 PM
dodgeguy71's Avatar
I don't know that the oil would hurt a diesel, GM says an overly oiled aftermarket filter can cause problems with your mass airflow sensor on your GM product(Gas). BHAF is far cheaper than the K&N setup, got around $100 in mine with filter,D-plate shield, outerwears and looks good.....I think.
Old Sep 1, 2006 | 10:19 PM
Diesel Demon's Avatar
K/n
I have a K/N filter in my 2001 and I have not had any trouble. I check the filter every time I change the oil in my truck. When i clean the filter I just give the filter a light coat of oil. I also check the turbo and I have not found any oil build up on the turbo impeller. I have had the filter in my truck for two and half years.
Old Sep 1, 2006 | 10:36 PM
Clayten's Avatar
DTR's Toad Wrangler
I have had mine in for 3 years no problems I like it
Old Sep 2, 2006 | 09:29 AM
Dr. Evil's Avatar
Do a search - this topic has literally been beat to death and there are still varying opinions. Its your truck - run it if you want. As for me, the K&N I had on my last truck went in the garbage.
Old Sep 2, 2006 | 12:43 PM
cumminsdriver635's Avatar
I like my K&N.
Eric
Old Sep 2, 2006 | 03:04 PM
HOHN's Avatar
Just say no to K&N on a CTD. Plenty of better options out there, imo.
Old Sep 5, 2006 | 07:40 AM
Hohn2's Avatar
what do you recommend Justy bones? Did you get moved in already?
(thread hijack)
Old Sep 5, 2006 | 10:03 AM
RowJ's Avatar
Probably true. But if I already had one, I would not be opposed to keeping it.
Biggest problem with the K&N is over cleaning and over oiling, IMO.
I would consider a BHAF a step backwards, if you ever intend to add HP!
JMO - RJ
Old Sep 5, 2006 | 10:08 AM
PourinDiesel's Avatar
Unless you live in a dusty area the kn is just fine.
These trucks arent going to last forever anyways!!
Old Sep 5, 2006 | 10:14 AM
Geico266's Avatar
I have 200K miles on a K&N. If you aready have one you are good to go. Just don't clean it too often. The dirtier it is the better it works.
Over oiling the K&N is a myth. I'm sure you can over oil it, but we are talking about 1/2 teaspoon of oil at the most. That is NOT going to cause problems with a CTD. The oil most guys see is from the turbo.
Old Sep 5, 2006 | 10:38 AM
infidel's Avatar
Almost 12 years and over 400k combined miles on both my K&Ns. I don't even pop the airbox open unless the filter minder says it's time or every 100k. To do otherwise is counter productive even with a stock filter.
My feeling is the only people who have problems with K&Ns are the ones who don't read the directions that come with them or people who have never owned one and who are just parroting something they've read on the internet.
I've seen more problems with BHAFs than K&Ns. It makes me absolutely sick to pop the hood on a rig I'm going to work on and see a BHAF with a big gap between the filter and intake tube caused by a slipped hose clamp or filter media falling apart from water. The BHAF type filter wasn't designed to be used in an application under the hood of a truck. You mainly see them connected upright to a steel tube on top of a stationary engine installed inside a building.
Old Sep 5, 2006 | 04:06 PM
supr's Avatar
Thumbs up
Thumbs up for the K&N stock replacement. No issues what-so ever. I think about 100k is about the time to clean them.
I think the stock box is OK, no water issues, decent air flow to it. I suspect this is OK up to mild BOMS/MODS. Just use some wheel bearing grease around both sides of the filter on the edges. This will form a tight seal.
It is easy to check how well it is doing when changing the oil, take the turbo boot off. Makes getting to the oil filter easier, about 1 min. to do.
The K&N stock replacement is about $70. I got mine used from a dude who got the big K&N setup. He said he spent the $250 or so for 20% more airflo, his opinion.
Lots of opions here!!
I think you have nothing to lose with the K&N. It is your least expensive option.
rob160
Jun 19, 2008 11:32 AM
staarma
28
May 1, 2008 11:10 AM
fitzydog
Oct 12, 2007 10:23 AM
kelley15
Aug 20, 2007 04:52 PM
jethroish
Mar 4, 2003 08:42 PM
