Sponsored by:
Sponsored by: CARiD
Interesting test on aftermarket air filters and stock filters
Old Oct 5, 2007 | 06:33 PM
fitzydog's Avatar
This is the website guys with bar graphs and I kinda wondering about this stuff and how much dirt is really getting through. I have only noticed more turbo whistle with my amsoil cone filter and afe intake tube nothing really other than that. I did notice my mileage drop off with the intake for some reason and higher temps while towing and not. I am thinking about puting on the stock intake to test it out. Later on and check out the write up. Aaron
http://www.duramax-diesel.com/spicer/index.htm
Old Oct 5, 2007 | 10:40 PM
75Dodge's Avatar
That is a really interesting study! Many good points are made about airflow of MOST diesels and that is most don't see a high enough RPM for a more free flowing filter to make much of a difference. Filtration is ESSENTIAL in diesels, especially turbo charged applications because it takes about 5 grams of fine dust to kill a turbo. Keeping the dirt out is the most important thing. Not only that but the OEM filter was restricted by just a few percentage points more than the others, again making little difference in our engines.
GOOD INFO!
Old Oct 6, 2007 | 12:08 PM
fitzydog's Avatar
Yea I thoght the write up was awesome. I have seen that my oil is dirtier quicker and a little loss of mpg with the amsoil vs the stock intake. I am rethinking this know.
Old Oct 6, 2007 | 12:54 PM
Connotaucarius's Avatar
This had been around for a while. Remember, this test was run on a "drop-in" style/facotry replacement air filter. They had no other air box mods. The engineers spent a long time engeneering a good filter and accounted for all the trade offs. The aftermarket total replacement system has a larger surface area allowing for more dirt but, much larger airflow.
Old Oct 6, 2007 | 03:32 PM
53 willys's Avatar
The Amsoil filter they tested IS NOT a nano dry filter...Amsoil nano filters are great filter
Old Oct 6, 2007 | 03:59 PM
GasganoFJ60's Avatar
Ditto
I bet it would have cleaned house if it was in that test....
..hmm...a filter..."cleaning house"?
no pun intended.
Old Oct 6, 2007 | 10:39 PM
Airsick's Avatar
These tests that they are showing were done back in 2004.... I am sure a lot has changed in that amount of time.
Old Oct 7, 2007 | 11:27 PM
Rare1's Avatar
I would not expect anything to change. As an example, Fram has been selling crappy oil filters for decades despite the negative laboratory results. Heavy advertising and snappy posters will sell anything.
Old Oct 8, 2007 | 06:36 AM
74dart's Avatar
Also the restriction test was done to 350 CFM. A modified truck flows way more than that.
Old Oct 11, 2007 | 08:21 PM
GaCamper's Avatar
That was interesting reading....I look at it this way. Unless your racing your truck or into big time mods why spend the money. Unless you have money to burn on the plastic intake tube & air filters that sells for over $200.00 &up.
Any filter that you can hole up to the light and see tiny holes which light is coming through such as some of the after market filters can't be good for your motor. The next time your at the auto parts store take a K&N filter out of the box and hold it up to the light. It will look like it has a bunch of tiny stars glowing through it. Which looks like tiny pin holes letting light through. I'll stay with the stock Fleetguard Filter for now...At least I don't worry about traveling dirt roads......
Old Oct 11, 2007 | 09:06 PM
dj_souvlaki's Avatar
from my experience the k&n clogs up alot faster and reduced my top end aswell as my fuel economy.
Old Oct 12, 2007 | 10:18 AM
bdewey's Avatar
testing your oil samples is the real truth behind air filters. If the dirt is getting in then your results will show. Doesn't matter what brand you run it all boils down to what is getting in the motor at time of oil sample.
Old Oct 12, 2007 | 10:23 AM
Clayten's Avatar
DTR's Toad Wrangler
So does that mean they filter better or worse?
bcfitzsimons
Jun 26, 2008 12:17 PM
Dodgezilla
36
May 31, 2008 11:36 PM
staarma
28
May 1, 2008 11:10 AM
