Just a Tease...
Old Aug 12, 2003 | 09:42 PM
  #46
TxDieselKid's Avatar
Re:Just a Tease...
This set compared to the old set dropped EGT's by about 200 degrees.
Do you have any numbers on your charge air temp?
As of know these twins have not shown what they can really do yet since I am limiting them to 60psi when they are capable of much more.
At about what RPM do they reach 60 at WOT?
dodgeman,
the line for testing these parts out starts behind my back! :P ;D
Andrew
Old Aug 12, 2003 | 11:13 PM
  #47
MCummings's Avatar
Re:Just a Tease...
Wanna guess who is right at the front of the line for testing/abusing/using?
Merrick Cummings Jr
Old Aug 13, 2003 | 06:32 PM
  #48
Battering Ram's Avatar
Re:Just a Tease...
Andrew,
I have no numbers on air temps yet but I may try later... right now I am trying to get backpressure measured. The twins will reach 60psi as low as 2000 rpm and that is when the clutch slips.
DM01,
NO!
Old Aug 13, 2003 | 10:36 PM
  #49
Re:Just a Tease...
[quote author=MCummings link=board=7;threadid=18103;start=45#msg171839 date=1060748006]
Merrick Cummings Jr
[/quote]
Merrick,
Am I reading this right? Your going to try and break a set?
Horace,
I would REALLY like to know those numbers compaired to the same numbers with your old setup. I know you only had that setup for about 3-4 months though. Maybe you could throw your old set on just for testing sakes!
So by 2000RPM, they can hit 60psi huh? About what RPM does the system start to "roll" up into the boost?
Andrew
Old Aug 14, 2003 | 01:05 AM
  #50
BigBlue's Avatar
Re:Just a Tease...
2000rpm's in first gear or second?
Old Aug 14, 2003 | 11:39 AM
  #51
Re:Just a Tease...
I have a 6 speed so I always start in 2nd... I am not able to reach full boost untill 4th gear. The RPM's simply rise too fast and I have to shift. In 4th the clutch will slip and if I am on it hard it will blow right through it... I will have backpressure and boost numbers tonight for all those interested.
Old Aug 14, 2003 | 02:43 PM
  #52
Re:Just a Tease...
Horace,
How do you plan on doing your testing? 1 pressure gauge or 2? Have you measured the boost in-between the 2 turbos? ???
Old Aug 14, 2003 | 05:18 PM
  #53
New Numbers!!!!
I hooked up my second DiPricol Tale Tail gauge today to do some measurements. First I took a boost pressure reading inbetween stages... I saw 25psi at 60psi of boost. I wasn't able to keep in it longer to see if it made any more since I like getting out of it at 60psi with my stock gasket. Then I hooked the gauge to the pyrometer fitting to take a backpressure reading. With boost at 60 psi (Taken at the boost port on the side of the intake "Post intercooler&quot I have 44psi of backpressure. I repeated this several times by reseting my tale tails and got the exact same number every time... 44psi of backpressure at 60psi of boost. I can't wait to take measurements again when I get the headgasket done and am able to raise boost.
Old Aug 14, 2003 | 08:44 PM
  #54
MCummings's Avatar
Re:New Numbers!!!!
[quote author=Battering Ram link=board=7;threadid=18103;start=45#msg172676 date=1060899530]
44psi of backpressure at 60psi of boost.[/quote]
Less backpressure than the HX-35 at ~40PSI!
Those are some really good numbers...
Merrick Cummings Jr
Old Aug 14, 2003 | 08:47 PM
  #55
Don M's Avatar
DTR Advertiser
Re:Just a Tease...
Dyno dyno dyno time!!!! 8)
Old Aug 14, 2003 | 08:52 PM
  #56
MCummings's Avatar
Re:Just a Tease...
[quote author=Don M link=board=7;threadid=18103;start=45#msg172741 date=1060912058]
[/quote]
Too bad it would only show how much power a used FE clutch can put down...
Merrick Cummings Jr
Old Aug 14, 2003 | 09:34 PM
  #57
Don M's Avatar
DTR Advertiser
Re:Just a Tease...
Its gonna take a big ol clutch to hold that monster I guess.
Whats it gonna be Horace?
Merrick,
Where have you been? You got yourself a new 12 valve and never call or e-mail me anymore :'(
Don~
Old Aug 14, 2003 | 09:50 PM
  #58
MCummings's Avatar
Re:Just a Tease...
[quote author=Don M link=board=7;threadid=18103;start=45#msg172765 date=1060914892]
Merrick,
Don~
[/quote]
Your avatar scares me.
All Joking aside..
If I had more info to give, I woud, but so far, it's just a Stack'd-n-Jack'd.
I think the last time I called you was after last years Muncie when we were convoying through D/FW and you were working.
I'll be out of town this weekend, but you want me to call you Monday ? ;D
Merrick Cummings Jr
Old Aug 14, 2003 | 10:29 PM
  #59
Don M's Avatar
DTR Advertiser
Re:Just a Tease...
Yeah
Don~
Old Aug 15, 2003 | 01:23 AM
  #60
Re:Just a Tease...
Wow, 44psi of back pressure at 60 psi is inpressive. Nice work Horace and JR.
Now just get a clutch, and some fire-rings, and dyno! ;D
Don~,
I remember Merrick making that call. That was back when you and I were friends :P
Andrew
PS. I still love you ~ ;D
