Juice
Old Jan 25, 2007 | 09:18 PM
WARFootball77's Avatar
Juice
If i buy juice W/ att what else do i have to do?
Old Jan 25, 2007 | 09:56 PM
mysterync's Avatar
You should be fine as long as your not on a stock auto! 4 inch exhaust and a intake will help your egts! Just make sure you hook up your fuel pressure gauge!
Old Jan 26, 2007 | 04:53 AM
Tsutter's Avatar
Save you VP44
Get a FASS system & save you lift pump.
Old Jan 26, 2007 | 06:35 AM
jriggs_18's Avatar
Im on a stock auto and it has been fine for going on 7mos. now, the wire isnt tapped anymore but Im about ready to turn 100k, just dont beat the tar out of it or it probably wont last
Old Jan 26, 2007 | 07:16 AM
mysterync's Avatar
fass is the best option but there are other choices! as long as you know what your fuel pressure is and you dont drop below 10 or so lbs your should be fine but it should be considerd a critical update!
Look in to Walboro , glacier and alot of folks run holley blues!
Old Jan 26, 2007 | 10:41 AM
jriggs_18's Avatar
ya the walbro kit is a good option, it hasnt done me wrong......yet, just make sure to get the prefilter
Old Jan 26, 2007 | 06:28 PM
cLAYH's Avatar
2 weeks before adding the Juice I replaced the lift pump. After I got the juice installed the fuel pressure was dropping to 1 psi when on max setting at WOT. I installed a Holley blue fuel pump on the rame rail that pushes into the stock pump. Now it doesn't go under 14psi.
So far the stock tranny is holding up.
5.0 Mustang Man
Oct 21, 2008 02:50 PM
SconsinSmoker
Feb 12, 2007 09:15 AM
bighornram
13
Nov 2, 2006 08:28 AM
razor6
22
Jan 20, 2006 03:43 PM
djcheez
Oct 15, 2005 04:13 PM
