injector pump
Old Oct 9, 2002 | 11:35 AM
bkay's Avatar
injector pump
Has any one had problems like the ones listed here<br><br>http://dodgeram.info/tsb/2002/14-002-02.htm<br><br>from using the Edge EZ
Old Oct 9, 2002 | 11:52 AM
Shovelhead's Avatar
Administrator / Scooter Bum
Re:injector pump
Since the EZ does not require you to attatch a wire at the injection pump harness, it less likely that a dealer will see any evidence of &quot;tampering&quot;.<br><br>However, if the tech uses the scan tool and is profiecent in reading the info it can pull out of the ECM, (not real likely in the past but they're getting smarter) the tech could possibly look in the history codes and see altered fueling parameters.<br><br>In other words If 'ya play, 'ya gotta be prepared to pay.
Old Oct 9, 2002 | 11:54 AM
Bob Wagner's Avatar
Re:injector pump
That TSB id for major fueling boxes that pierce the pump wire.<br><br>The Edge EZ does not pierce the pump wire
gablekevin
Sep 19, 2006 12:12 AM
jbevly
Sep 5, 2006 03:59 PM
loveturbowine
Jul 26, 2005 05:50 PM
Puke
May 22, 2003 12:18 AM
